14 98 just upgraded to 1250 from 1200
0 ,09 Iron883N idling weird, sputters on accelerating from idle or low revs.
Last Post: tussuck
0 Show us your Bike next to a Bridge
Last Post: Lone Rider
14 Post your Bike in a Cemetary Pic
0 Need help with S&S GB carb
0 New from Washington
Last Post: DBH
8 Never Forget
Last Post: sglock45
0 Carb flooding
0 question about XLCH manuals
0 2019 York Bike Week (9/18-21)
0 Chain kit
Last Post: wrkdWS6
0 dual carb heads on ebay
0 Shoei GT-Air II FF Helmet Review
0 2011 Nightster--First Impressions
0 Bad Primary Oil Leak
0 7” Headlight conversion on solid mount
DéDé's Avatar
DéDé DéDé is offline
Sportster/Buell Model: XL 883
Sportster/Buell Year: 04
Other Motorcycle Model: Street Bob
Other Motorcycle Year: 08
DéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to beholdDéDé is a splendid one to behold
Default Swingarm Bearing Change Rubbermount
ok, to continue this thread - did some nice rides without any issues so far. but now with 67.000 kilometers I had some noticable play in the rear fork and felt some wobble along grooves and it was clear that I had to change the swingarm bearings, this is normal wear after 67000 kilometers I think. Here are some pics.
Took rear muffler and header pipe off, brake caliper, belt guards - and rear wheel out.
For the left side swingarm bolt I needed an impact tool, after that everything came off easily
20190810_121901 by DéDé1963, auf Flickr
20190815_120617 by DéDé1963, auf Flickr
20190815_120632 by DéDé1963, auf Flickr
20190815_161953 by DéDé1963, auf Flickr
DéDé's Avatar
took swingarm out and pressed bearings out - no problems
20190815_134646 by DéDé1963, auf Flickr
20190815_131600 by DéDé1963, auf Flickr
DéDé's Avatar
for assembly I put new bearings in the freezer and warmed up bearing seats a little bit with a heat gun, so assembly was an easy fix. Got also a new tire on and now it handles perfect
...to be continued
20190816_174628 by DéDé1963, auf Flickr
20190816_182725 by DéDé1963, auf Flickr
DéDé's Avatar
one of the mods moved my thread, it´s ok so far but please put correct title
swingarm bearing change rubbermount
DéDé's Avatar
ok, thanks
herostar herostar is offline
Sportster/Buell Model #2: XB9R
herostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really nice
Thanks for the pictures and info.
Were there any hang-ups besides the impact wrench that the rest of us should be aware of?
Did the new bearing/tire fix your wandering problems?
2007 XL1200R - Denver, CO
old dog old dog is online now
old dog is an unknown quantity at this point
See top of post 3
DéDé's Avatar
ok, I can say there is no chance to press in the new bearings till seated (clip gives your seated position) without freezing new bearings and heating up bearing seats.
Impact wrench (electrical) only for the left side in my case.
I did this work twice before on other bikes - 05 an 04 - there the bearing seats needed to be worked up just a very little bit (Dremel sanding and polishing) they were to tight for the oem bearings
