0 Primary thread
Last Post: RandallM
Last Post: ZTatZAU
Last Post: Jhbox13
Last Post: Randy_rots
0 Oil system prime
0 1971 with a Mag
Last Post: Whitewalls
0 1977 xlh
0 Nicks custom cycle
0 old school prism oil filter/cooler
Last Post: 73HEAD
0 Informed reviews!
0 Regulator test 1974 xl
Last Post: Jaime1840
0 Allegheny National Park III
0 WTB--shocks
Last Post: Doc308
0 Digital volt meter
0 Clutch adjusting screw
0 85 Ironhead, Kiffy Stand Question
0 Pegs vs floorboards
Last Post: riceburner
  #53011
Old 2 Days Ago
The best thing about this Forum is the brain power that is here.
Old 2 Days Ago
Graywolf Graywolf is offline
Graywolf
Old 1 Day Ago
Old 1 Day Ago
Old 1 Day Ago
Old 1 Day Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Superheated steam is one link in a chain for extraction. That unit is most likely one of about 5 or 6 pieces that would be joined together.
Or maybe someone is just a really big tea drinker??
Old 1 Day Ago
Super-heated steam is used in a lot of other processes too. We had two of the big steam boilers in each of the chemical plants at the phosphate mine. The steam was used to process sulfur to make sulfuric acid. The sulfuric acid was used to leach the phosphate out of the ground up phosphate ore. The phosphate is used in almost all fertilizer products, some animal feed ingredients and even added to some processed human foods. The excess steam generated in burning the liquid sulfur is used to run steam turbine generators producing some of the electricity needed in the chemical plants.
Old 1 Day Ago
Yes Sir you are 100% correct.
Quite interesting how some controlled temperature changes to certain elements can create unique end results/products.
Old 1 Day Ago
ChinCactus's Avatar
Steam is also used to get the shiny crust on Italian bread.
Old 1 Day Ago
Keep it running
