5 Nightster tyre type "-" or "B"
Last Post: b0fh
0 Range With EFI 3.3 Gal Tank
Last Post: corndog76
0 Issues with my jiffy stand... HELP!
0 2009 Speedometer Wiring/Colors
0 Hi From Atlanta
Last Post: slamtry
0 roadside belt change
Last Post: jazzman
0 Too HOT to ride?
Last Post: Kbetts
Last Post: mrbreezeet1
0 Sonnax, Timken, Torrington
0 Need Float for Zenith, or a replacement Zenith
Last Post: Gulf Coaster
0 External breathing systems
Last Post: Firehawk
0 Which Battery?
0 19'' Cast/Chrome Front Wheel
Last Post: knut
0 Sportster Cobra seat
0 Cylinder Head Temp. How hot is too hot?
0 Right rear turn signal out 2002 XL1200C
0 Sleeve cylinders?
0 so where the heck is insane shane?
Old 16th December 2019
1Scooter 1Scooter is offline
1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold
The 05 Sportster has a crankshaft sensor. You can NOT alter it or "tune" it. You can get an aftermarket ignition modual which you can increase the rev limiter and change the spark advance curve. Get a K&N air filter and free flowing exhaust while you're at it. Those 3 things will wake up your Sportster . . . without a tune.
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to beholdstikflote is a splendid one to behold
Which after market ignition module ,
would you advise
Folkie Folkie is offline
Originally Posted by stikflote View Post
i want to get the bike to run a bit smoother, and would like it to breath better .
the problem is were do i start its a 05 carb XL 1200C
I'd start by tuning the bike as it is now, before making changes to it.
Check out the carb tuning stickies:
All things Carburetor- Tuning, Jetting, How-To Sticky Index
