0 Resto-Repair 84 ironhead
0 Mid West Meet & Greet
0 Digital odometer
Last Post: onadraw
0 My 900: half-H, half-CH
Last Post: mrmom9r
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 15 sporty braided rear brake line
Last Post: 201648Rider
Last Post: jazzman
Last Post: Bored now
0 Smaller turn signals
Last Post: lehel
Last Post: lehel
0 xied or x14ied?
Last Post: Joe_jeep
0 Spark Plugs
0 Xlch spark plugs
0 Diagnostic code ?
0 Solenoid issue?
Last Post: Gulf Coaster
Last Post: Hellbent_4
Old 26th February 2020
Racepres's Avatar
Racepres Racepres is online now
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
Default Swingarm??
Quick question... I am assembling a DragBike on a rigid mount late model Sporty Frame... wondering which swingarm is Stronger... post '05 or Earlier models??
Heck are there fitment problems with an '05 up swing arm in an earlier [like a 2000] frame???
I want Long and Strong!!!!
Thanks for looking!!!
BKB's Avatar
BKB BKB is offline
The frame changed in '04 to accommodate the rubber mounted engines. The swing arm on those has a completely different pivot set up. You will need to stick with a swing arm that will fit a '03 or earlier frame. Have fun.
Racepres's Avatar
Yea... I see that now... the pivot did indeed change...I was really looking at the Axle end... thinking it may be an Improvement on the Hollow [tubular] early arm...
Now, Maybe I cut the early Arm long and the late one short and graft the late Axle end onto the early Arm!!!!
Should end up at a good [long] length, as well as a possibly stronger axle Area???
Only gonna need longer shocks then... Maybe...
Thanks for the heads up... being basically an Ironhead Guy... I don't know what I should about later Models!!!!
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
Read my comments:
http://victorylibrary.com/brit/chassis-2a.htm
Racepres's Avatar
Originally Posted by kitabel View Post
I have seen that... But, I am Drag Racing.. and longer swingarms... or better yet Rigid tail sections [with Wheelie bars] are Quicker... long as they don't Flex too much..
I am going without wheelie bar so long and Sprung [shocks]... If I get too much flex.. I will do Bracing [strut]... tho I don't want the Weight!!
Thinking a Cross Member between wheel and Pivot at Minimum tho... so thanks for the "curved" info!!!
Old School Drag Racers stretched the Front... them guys can't keep up now..
Thanks For the Link... appreciated..
Be sure to check the Sportsterpedia also for newer model information.
Here is an article on rubbermount engine mounts showing the swingarm configuration.
http://sportsterpedia.com/doku.php/t..._engine_mounts
Racepres's Avatar
^^^ Good info, especially since I never Inspected a Rubbermount Sporty!!!
Thanks
