Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Hammer Performance
0 Resto-Repair 84 ironhead
0 Mid West Meet & Greet
0 Digital odometer
Last Post: onadraw
0 My 900: half-H, half-CH
Last Post: mrmom9r
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 15 sporty braided rear brake line
Last Post: 201648Rider
Last Post: jazzman
0 Smaller turn signals
Last Post: lehel
Last Post: lehel
0 xied or x14ied?
Last Post: Joe_jeep
0 Spark Plugs
0 Xlch spark plugs
0 Diagnostic code ?
0 Solenoid issue?
Last Post: Gulf Coaster
  #51
Old 3rd September 2018
MatHormell's Avatar
Sportster/Buell Model: XL883R
First impression, pulling it out of the box, is how massive this thing is, at least for a Sportster part. The picture doesn't really convey it very well, this thing is BIG, and it's heavy too. Holding it in my hand and looking at it, I was wondering how the hell it would even fit between the heads on a Sportster. A Twinkie, sure, but it's so much bigger than the HPI XL piece that it makes you wonder.
The manifold's interior is nicely done, in terms of it's shape and surface finish. None of the casting flash and other flow-killing flaws that you see in so many castings. Almost a bead blast finish, too, which works well. 99% of flow has to do with shape and size and casting issues, though, surface finish is in the noise by comparison. It's not badly shaped and it has no casting flaws.
The manifold is an odd piece to hold and look at. I mean, the inlet is just enormous compared to the rest of the piece. This picture gives you a sense of that. It has this sewer-pipe sized inlet.
The outlets, however, are a different story. Very, very close to the dimensions of the stock manifold, only a little bigger. The o.d. of the outlet is stock, too, so there's not a lot of room to enlarge it. And the injector boss is really not well done, it presents much more obstruction than it needs to.
Aaron,
are you planning to work on FI manifold ? Im kicking around the idea of converting over to Fuel injection with Micro squirt and in the middle of figuring out what TB and manifold I want to use.
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
Old 8th September 2018
Sportster/Buell Year #2: 2008
No Bout aDoubt it.
When the idea presents itself, in due time, and can be elegantly machined, Hammer will produce the efi throttle body.
One hundred thirty ponies????
Old 26th February 2020
Randy_rots Randy_rots is online now
Randy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of light
What is the P/N for this kit?
Is it still available???
I wonder if that manifold would fit 2004 heads with old manifold flanges (not 07+ type)
rocketmangb's Avatar
The manifold is about .120 wider than the Carb manifold
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
http://www.surdyke.com/PartsMain.asp...umber=27200026
Old 27th February 2020
That does not matter, I can make it fit.
I'm concerned about the screws.
Thanks George!
Hammer might know about the bolt spacing
