0 Resto-Repair 84 ironhead
0 Mid West Meet & Greet
0 Digital odometer
Last Post: onadraw
0 My 900: half-H, half-CH
Last Post: mrmom9r
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 15 sporty braided rear brake line
Last Post: 201648Rider
Last Post: jazzman
Last Post: Bored now
0 Smaller turn signals
Last Post: lehel
Last Post: lehel
0 xied or x14ied?
Last Post: Joe_jeep
0 Spark Plugs
0 Xlch spark plugs
0 Diagnostic code ?
0 Solenoid issue?
Last Post: Gulf Coaster
Last Post: Hellbent_4
Old 27th February 2020
Folkie Folkie is offline
No. It looks like the connector to the lower right on this adapter:
It's grey, on a red wire. You may have to fish around under the frame behind the seat, to find it.
SonWon SonWon is offline
Sportster/Buell Model: Superlow 1200T
Sportster/Buell Year: 2016
SonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond repute
I used a relay straight off the battery like Folkie said, works great.
The advantage of using the B+ connector instead of going straight from the battery is that it goes through the Maxi Fuse. Take that one fuse out, and everything's disconnected.
Old 28th February 2020
vagrant318's Avatar
vagrant318 vagrant318 is offline
vagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud of
Take power from the B+ connector under the back of the seat. Put an inline fuse in the feed you take for the connector. Use a relay powered by the orange/white ignition switched accessory circuit (eg from the lighting connector in the same area as where you find the B+ conector), so that the feed is only live when the ignition is on (otherwise you may accidentally leave the grip heater on and drain the battery).
That's for a 2004+. If you have a 2003 or earlier, there is no B+ connector. Instead use the silver terminal of the circuit breaker inside the electrical side cover.
I'm curious about the 03 and earlier, I'll have to pull off the fuse box and investigate what you are referring to
Sent from my Pixel 3a using Tapatalk
Don't really know about the '03 and earlier, but that's what Harley say to do.
brixtonanima brixtonanima is offline
Sportster/Buell Model: 883r
Other Motorcycle Model: Excelsior Henderson
brixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant futurebrixtonanima has a brilliant future
Yea I’ll have to find the harness. Folkie, do you know which harness will work on the 05? I was at the dealership and the guy said that none of the, would work. He had that one in the picture you posted as well.
The one in the pic is for 2004+, but what it does is provide multiple connectors, instead of just one. You can either get a plug to put on your wire, so you can plug into the socket that's there on the red wire, or forget the socket and just splice into the red wire.
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
A bit more work, possibly, but I had an empty "way" in my OEM fuse box, unpopulated with any metal contacts.
I got a pack of new contacts for the OEM box, and populated the empty way(s) with new terminals. Put my accessories on that. Think it was an unstitched feed I used....via the main big fuse of course
Thanks so much. Do you have a part number? Also, as I understand it, by wiring to this connector, it is always live and not operated by the key?
