0 Resto-Repair 84 ironhead
0 Mid West Meet & Greet
0 Digital odometer
Last Post: onadraw
0 My 900: half-H, half-CH
Last Post: mrmom9r
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 15 sporty braided rear brake line
Last Post: 201648Rider
Last Post: jazzman
Last Post: Bored now
0 Smaller turn signals
Last Post: lehel
Last Post: lehel
0 xied or x14ied?
Last Post: Joe_jeep
0 Spark Plugs
0 Xlch spark plugs
0 Diagnostic code ?
0 Solenoid issue?
Last Post: Gulf Coaster
Last Post: Hellbent_4
Old 27th February 2020
Racepres's Avatar
Racepres Racepres is online now
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
Originally Posted by madnss View Post
Just axle choice is all.
Oh... I think a Stock axle will be fine.. Just in case I still have an Un-obtainium one as well...
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
I built one 6/8“ over and made it 2” wider. Not sure how to explain it but I’ll try. Didn’t have a jig but used a flat plate, squared it up and clamped everything down. Cut all but two inches off the axle side. Got some metal and drilled/cut out the axle slots. Layed them on the outside original arm ran a cross brace to tie it together. Added gussets top and bottom for reinforcement. Never had a problem. Good luck,let us know what you come up with.
Racepres's Avatar
Good Info... I do Not need Wider... Largest engine that will go in it is a 114" and it was kinda hard on spindly chassis... but, that is when we were really trying to set the world on Fire also..8.90's an 150+
Won't be doing that with this one!! Nor to Myself!!!!
cycowrencher's Avatar
The info I have pertains to an 04 swingarm that had the 03 and older frame mounts welded on. We extended the arm 8 or 10 inches by "slugging" the original axle holes. I used rosette welds to secure the extensions onto the legs of the swingarm. The 04+ arm is 1.5 inches wider than the 03 and older arms. This allowed us to run the 17x4.5 deuce wheel with a 180 shinko hookup (think of it as a drag radial) I was able to purchase the correct size "slug" material from a metal supply house. I used solid stock for the slugs.
Sent from my LM-V405 using Tapatalk
Racepres's Avatar
Thanks for the Visual...
I think I may prefer the Newer Axle Adjusters and swingarm section...
