0 Engine Guard question
Last Post: RedPearl1200
0 Primary cover screws... Washers??
Last Post: Monte03
0 Clutch Went Out Of Adjustment - Grenade Plate
0 Clutch spacing 1979 1000xlh
Last Post: Hardtail28
5 Mick Off Line
0 Powder Coating Spoked Wheel Rim
Last Post: NP72Iron
0 Round Air Cleaner Poll
Last Post: BSA Bob
0 shifter shaft bent
0 why you can't be seen
0 time will tell, but...... (blacked out: fad?)
0 is a buell a harley
0 Mad Dogs and Englishmen
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 Technician VS Mechanic: What's The Difference?
0 Cocktail Shaker Exhaust
0 1200S Fork Slider Differences 1999 to 2000
0 Zenith / Bendix Accelerator pump
Last Post: ZTatZAU
0 Model H and DR DICK, Weekend Shop Videos
0 Seeking information on long lost "race" parts
0 Need Correct K & N Filter #
Last Post: Steve S.
0 Wheel bearings, steering race, or is it nothing?
Last Post: OzarkXL1200R
MAJBJD (79), 3sporty53, Jt1200r (69), 69camfrk (57), nooz (48), rixta (47), saltman241 (44), Jhard206 (36), Screamin' 07 XL (36)
Old 30th May 2022
NthnlKrse NthnlKrse is offline
Sportster/Buell Model: 1200 XL
NthnlKrse is an unknown quantity at this point
yes I had my handlebars changed so all the controls were rewired, as well I replaced my stator
Old 30th May 2022
I would have to double check but I believe my is US made my VIN starts with 1HD
Old 30th May 2022
Did you make any wiring changes at the TSM (Under the Battery)?
After checking the Neutral Switch wiring, I would certainly pull the battery & make sure the connector to the TSM is clean & then fully re-seated.
For Sportster Tech Info:
Old 30th May 2022
lostNdallas's Avatar
lostNdallas lostNdallas is offline
lostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond repute
I forgot to mention that the Neutral Light goes out as well, I've noticed that if that light does not come on I cannot electric start although if it is on then the electric start works fine
I would think this points to a possible neutral safety switch issue.
The journey IS the destination. (L-1,C-1,R-3)
