Last Post: XL Dane
Last Post: rockrock513
4 What will 10 cents buy?
Last Post: Iron Chuck
Last Post: Gulf Coaster
Last Post: DollarBil
Last Post: Proteus
Last Post: Proteus
Last Post: Proteus
Last Post: class of 82
Last Post: soundnav
0 Swapping out single speedo for 1200 dual gauge setup
0 HTML Code
0 AGM battery for 76' XLH
Last Post: The Doctor71
Last Post: sprink
Last Post: coastie56
0 Riding music
Last Post: sprink
PlanB, Cuco6924 (74), 1200sporty (63), iron68 (49), LifesHarlequin (36), mattosm (35)
Old 6th August 2020
Old Rocker's Avatar
Old Rocker Old Rocker is offline
Other Motorcycle Model: Dyna FXDF
Other Motorcycle Year: 2011
Old Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the roughOld Rocker is a jewel in the rough
Default 2012 Superlow 883 settingfront Sag,need spacer Diameter info.
Can anyone tell me the "outside diameter" measurement of the PVC spacer for the Superlow 883 39mm Forks,i'm not sure i'm asking this correctly,maybe it's just simpler to ask what diameter PVC Pipe,do i need for a fork tube suspension spacer.
You can probably tell i don't know how to ask this,but hopefully someone will get what i'm babbling on about.
Cheers.
Old 6th August 2020
Looks like 1" outside diameter...
These links should help you:
Sportsterpedia section on front forks:
http://sportsterpedia.com/doku.php/techtalk:evo:susp01
Progressive Fork Springs Install - 11-1527 Kit
http://xlforum.net/forums/showthread.php?t=2006111
Extensive information on setting up suspension:
http://sportsterpedia.com/doku.php/techtalk:ref:susp07
Old 6th August 2020
Old Rocker's Avatar
Many thanks.i'll have a read up
