0 Hello from Virginia
Last Post: EdHD
0 New to me 1975 sporster xlh
0 Coil suggestions please!!!
0 Sifton pre-filter 40-0387
Last Post: ThenCameHarry
0 Gender sensitivity:
Last Post: Andy56
Last Post: Andy56
0 No brake lights - Sporsterpedia, I'm going in
Last Post: Andy56
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: d10221
0 05 sportster custom and bassani road rage
0 Xlcr1000
Last Post: xlerate
0 2021 Christmas List
Last Post: xlerate
0 Can't find a bowl gasket anywhere, options?
0 Keep an Old sportster or buy New
0 2009 Iron 883 Wont Start!
Last Post: jsaintmartin
0 Primary Leak
Last Post: BitterOldMan
Last Post: AZbiker
Last Post: bikeridermark
0 Shock mount sheared
Last Post: AZbiker
0 Happy Birthday Folkie!!!
0 Trying to figure out if starter or stator
0 33.4 Triple Tree Rubber Riser Bushings
Last Post: Maxwell#256
Last Post: duffy
0 Sportster Cobra seat
dho45 (60), Mark914 (57), diesel_lv (55), papabearstills (49), BavariaNight, pitchlynk22 (40), m3ntal (35), wrkdWS6 (33)
  #81
Old 18th September 2015
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
Originally Posted by biknut View Post
That is a possibility, yes. As old as your seals are it doesn't matter, you need to replace them as a matter of maintenance.
So, my 25 year old seals that show no sign of an issue should be changed? I'm on the fence of that or don't fix what ain't broke.
John
Old 21st September 2015
Cripy99 Cripy99 is offline
Sportster/Buell Model: 883xl hugger
Cripy99 is an unknown quantity at this point
John you were right. There was and extra vacuum line going to the petcock that I failed to hook up.
Sent from my SM-N910T using Tapatalk
Old 22nd March 2017
AGHD AGHD is offline
AGHD is an unknown quantity at this point
Great guide, I'm doing this soon.
Found an extra gasket that will fit, but maybe no difference or maybe creates new problem?
Any thoughts?
https://ibb.co/mN74Tv
Old 8th September 2020
Proteus Proteus is offline
Sportster/Buell Year: 2012
Other Motorcycle Model: BMW R 75/5
Other Motorcycle Year: 1972
Proteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond reputeProteus has a reputation beyond repute
Hi all,
digging up an old topic, I know, sorry...
I have to replace my heads intake gaskets on my 2012 EFI Sportster.
I have almost no imperial tools but the normal wrenches, no socket nor tube spanner wrenches.
I'm looking for the size of the tube wrench needed to get the breather bolts out the heads, metric 13 or 14 don't work.
Thanks!
Every man should have a hobby he can't afford...
Folkie Folkie is offline
It's a 9/16" AF. You'll need a deep socket, ideally a six point one. The amount of engagement of the socket with the bolt is quite small, and with a twelve point socket it's likely that the socket will slip and damage (round off) the flats.
harley506d's Avatar
Sportster/Buell Model: 1200c
And, they come out easier if the engine is hot.
Many thanks guys!
Let's jump the on Beemer and get that tool!
Old 17th January 2021
d10221's Avatar
d10221 d10221 is offline
Sportster/Buell Model: XL883N
d10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to behold
2017 XL883N 5500 KM, ... I think I found a leak in the intake manifold ... front cylinder side
Brake cleaner spray on idle makes it want to stop ... when hot
Any chance anyone has a video ?
Part numbers for the seals/gaskets that have to be replaced ?
What grease ?
Would you need to remove the tank ?
Will it be needed or maybe is better to remove the air filter assy?
Leave the injectors, remove the injectors?
Disconnect everything ? or leave it all plugged ?
Bolt/torxs sizes, torque ? untorqueable ?
I'll check the bike again and see if I can answer some of my own questions
17' XL883N (South Africa) | "I told you ... I don't know what I'm doing"
d10221's Avatar
Index No. Part No. Description Model(s)
1 2481M SCREW ALL
2 3987 BOLT (4) ALL
3 4798 SCREW ALL
4 16361-07 BRACKET ALL
5 26995-86B SEAL (2) ALL
6 27216-95 SCREW ALL
7 27327-07A FLANGE (2) ALL
8 27628-01A KIT, idle air control (IAC) motor ALL
9 27629-01A KIT, throttle position sensor (TPS) ALL
10 27200024 INDUCTION MODULE ASSEMBLY, with fuel rail, fuel injector, intake manifold, TMAP sensor, cap, IAC Kit, TPS Kit, hardware kit ALL
11 27693-07 FUEL LINE KIT, with 27216-95 and bracket XL1200C, XL1200CB, XL1200CX, XL1200T, XL883L, XL883N
27829-10 FUEL LINE KIT, with 27216-95 and bracket XL1200X
12 27700-07 KIT, hardware and O-rings ALL
13 27701-07A CABLE BRACKET ALL
14 27704-07 FUEL RAIL ALL
15 27706-07A FUEL INJECTOR, with O-ring (2) ALL
16 27707-07 INTAKE MANIFOLD ALL
17 32319-07A SENSOR, temperature manifold absolute pressure (TMAP) ALL
18 90383-98 CAP ALL
Is that it ?
d10221's Avatar
Originally Posted by d10221 View Post
Bolt size, torque ?
untorqueable! ... bigger than 12 and smaller than 13 , smaller than 1/2 bigger than a 7/16 (that is all I have)
Its a 1/2" bolt head
yes, to access right bolt (3987 ... 1/2 inch head)
