Last Post: davesz1r
0 oil transfer valve
Last Post: The Doctor71
0 Ground Up Beginner Build
Last Post: Edster
0 Sportsterpedia Progress
Last Post: hondo
0 "S" model specific Q&A
Last Post: Edster
0 80 xl1000 oil not circulating?
0 73 XLH Total Power Loss
Last Post: sleighcrane
0 Tappet blocks and tappets
0 Info needed on mini sumps.
0 Do you stare
Last Post: Oldmxdog61u
Last Post: BigLerowski
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: Redbeard2
0 New Guy with Experienced Bike
0 Another Podcast Interview for Parrothead
0 New guy from IL
Last Post: jharback
0 So which cams will fit?
0 old style fender skirted
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 21st March 2020
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Default muffler balance pipe
Hi all,
i want to change my mufflers , in the book it says use a new gasket ,
but what keeps muffer connected to the cross over pipe ,
i need to swap them for some quieter ones
Keith
Old 21st March 2020
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
The crossover is bolted to each muffler and bolted to the engine. Do you have the stock mufflers? My stock mufflers were quite, How about the FSM?
Old 21st March 2020
@oldboy, YES think i do have the stock mufflers, at least ones that were on bike ,
how are the mufflers bolted to cross over pipe bracket?? ,i dont have a FSM,im using a
CLYMER manual for 2005 XlC 12OO
Old 21st March 2020
motorfish motorfish is offline
Sportster/Buell Year: 2012
motorfish is an unknown quantity at this point
There is a flange on each muffler, bolted to the crossover's pipe bracket.
Needs 1/2 inch socket and flat spanner to undo the bolts. Loosen the headers at the cylinders before removing mufflers, to unseat connection to the crossover pipe.
Old 22nd March 2020
Folkie Folkie is offline
You're going to have a job to find anything quieter.
What do you mean: 'how'? With screws, through the bracket and into the muffler.
Get yourself the proper manual.
Old 22nd March 2020
I hAVE Asked one HD shop about one they said they dont have any ,
,if any one in UK can tell me where to get one, or have a used one
to sell me please let me know
Old 22nd March 2020
im talking about the flange on muffler not cylinder head flange
its got no bolts threw it .i cant understand what it does
Old 22nd March 2020
Part #14 is the screw that screws the muffler to the crossover pipe.
Old 22nd March 2020
No not that bit, in middle of muffler is a round stub sticking out, which goes between no 14 and 17 into that 1 inch
Old 22nd March 2020
'That bit' (screws #14) is how the muffler is attached to the crossover pipe.
The crossover pipe fits into the crossover port on the muffler. This is what allows the crossover to work. There is gasket that fits in the port on the muffler, which the end of the crossover pipe presses against to seal it. This joint is held together by the muffler being screwed to the pipe/bracket (screws #14).
