0 "S" model specific Q&A
0 Highway cruise speed
Last Post: lespaul6
0 Adjusting Drive Belt While On A Lift
0 N65C or N65A
Last Post: lespaul6
0 Tappet blocks and tappets
Last Post: Scott
0 Turbo Iron 883
Last Post: Ghostdog
0 Chinese S&S carbs
12 Crankcase breathing?
Last Post: DJCBlue
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sportster Fork Upgrade
Last Post: Redbeard2
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 Ground Up Beginner Build
Last Post: Paul.W
Last Post: PetesPonies
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 2nd June 2020
MkC MkC is offline
Sportster/Buell Year: 1986
Other Motorcycle Model: Triumph
Other Motorcycle Year: 2002
MkC is an unknown quantity at this point
Default Crank Seal Missing; Is My Engine Damaged?
Bought this 1986 883 last summer; my first Harley, not my first bike. Purchased it from the original owner - a guy with a reputation for taking care of his stuff, including his motorcycles. For years he rode it as his primary transportation and the bike has been through a lot. Sometime in the mid to late 90s he had traded some work and had a guy put in a 1200 kit, along with mild cams.
Fast forward to a few months ago and I've got it in my garage with the engine partially torn down to repair oil leaks at the lifter blocks and primary. While the primary cover was off I decided to replace the stock clutch with a Barnett Scorpion due to a bit of wear on the original clutch hub causing wobble. When I got ready to reinstall the engine sprocket I noticed there was no seal on the crankshaft . I have no idea how long this machine has been running with no seal between the crankcase oil and primary oil, but its got to be a long time.
Question: how much damage is possible? Engine has always run strong with no knocking and the transmission shifts fine. The clutch was slipping under a hard pull which is one reason I upgraded the clutch. Do I need to pull the engine and split the cases to check for damage or just install the missing seal and ride on?
Old 2nd June 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
How does the bearing look? Pictures are always good. Harley oil pressure is nothing to brag about compared to plain bearing motors.
This all I have for you. I';m busy.
http://xlforum.net/forums/showthread.php?t=2073932
Stock sucks.
Traveled to
Old 2nd June 2020
juzyHD's Avatar
juzyHD juzyHD is offline
Master Bike Builder
Sportster/Buell Model: sportster 1200
juzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond repute
Are you sure that the seal is missing? When the sprocket is off, there is a gap between the seal and crank shaft, cause the sprocket is running in the inner lip of the seal.
I doubt it is possible to run without the seal cause there would be a massive oil migration between the engine and the primary...
Pay atention to the clutch wobble, it can cause a lot of damage if the rotor hits the stator...
Old 2nd June 2020
MkC MkC is offline
100% positive it’s not there. I’ve got photos but not sure how to post them here. I had to remove the crankshaft sprocket in order to remove the clutch. Got ready to reassemble and noticed the shiny ring on the crank sprocket where a seal lip used to ride. That’s when I looked closer at the crankshaft splines and can see the back side of the tapered roller bearing on the crankshaft. Looked up the online parts breakdown and found out there’s supposed to be a seal there that is definitely missing. I never removed it and there isn’t one on the workbench either.
Old 2nd June 2020
You need to post pics so we can see what you see.
Find a pic hosting site, sign up, upload the pics to it and post a link to them here.
The engine won't run well without that seal.
Crankcase pressure and primary windage gets all out of whack and oil gets everywhere and you'll know it.
So if the engine had been running without issue, chances are the seal is there.
Old 2nd June 2020
juzyHD's Avatar
Master Bike Builder
Interesting! I had a bad seal and the oil was migrating from primary to the engine.
I don't know if there are any specific reasons for failure caused by this situation, experts will have to tell..
About the clutch wobble, check sportsterpedia clutch section on this topic and there is a thread http://xlforum.net/forums/showthread.php?t=1971026
for more info...
Old 2nd June 2020
MkC MkC is offline
OK, here's what I see with the crankshaft sprocket removed. Correct me if I'm wrong, but I think something is missing here.
Here you can see where a seal lip used to ride.
Old 3rd June 2020
MkC MkC is offline
Photo added. And yes, oil seems to be everywhere. I know there was a leak out of the lifter blocks, but there was a lot of oil coming from the breather hose that the PO routed to the rear of the engine. I thought there was also an oil leak from the old oil lines and possibly from the starter gasket. Really it was hard to tell where all the oil was coming from, so I decided to reseal everything I could without pulling the engine. The areas I know were not leaking were the cylinder base gaskets, the heads, and the engine cases themselves.
Old 3rd June 2020
I get it now.
But where did the seal go?
You didn't find it in the primary side??
I'd put it in neutral, set the sprocket on and gently turn the engine over with the plugs out.
See if you can feel any bumps or scratching from the bearings.
Don't know how long it's been like that but the transfer of oil between those bearings leaves less oil elsewhere.
You should have had oil coming out the trans vent as well as the breather.
Once those outlets are compromised, crankcase pressure starts imploding gaskets elsewhere, including possible lifter block gaskets, rocker box gaskets and case seals.
It can pop the oil tank cap off and spit oil from there also.
I don't believe you have to split the cases...unless the bearings don't feel right when you spin it over by hand.
But that issue can increase heat buildup so pay attention to noises.
Old 3rd June 2020
do not think you have much to worry about. that bearing is not pressure fed it is a gravity/splash system so there would not be much oil there to begin with.
also, that seal isn't that large. do you see any of the cup of the seal? if it was a rubber coated seal, the stuff could have broken down, seal got loose and spun. there should be some signs or it was left out by previous work.
that drain hole is fairly big so any oil spun off the crank pulley probably was spun off into that drain, not that much space there anyway. however, some oil probably did make it into the primary and out the vent as the engine breathed out of it also.
you could set up a dial indicator and measure axial crank play. also drag a magnet across the bottom of the oil bag.
fly it and watch it.
