Last Post: supermotolew
0 Info needed on mini sumps.
0 Ironhead carbs
Last Post: spacecoast
0 fork tube cap
Last Post: Heff
0 Another Wrap Post
0 Graduated to Ironhead
0 Hammer 1250
5 1988 xlh1200//// dynatech2000i shorting/grounding help
Last Post: jtb%sporty
0 Sticky Ironhead trans
Last Post: BigLerowski
0 Top end failure
Last Post: Mission1
0 Chinese S&S carbs
0 yost power tube guy
0 XL Forum T-Shirts ?
Last Post: Flying Monkey
0 HF bike lift
Last Post: Rgm883
0 No spark
Last Post: awright2009
0 Piston and cylinder condition
Last Post: duffy
0 Bikers choice main jet threads
0 Cleaning carbon build-up
0 Don't Think I Ever Did This
GWR (68), Helimad (66), dragon62 (58), metromix (58), Repohio (57), acenorm (52), reblu (44), jesterdoc (44), glucky7 (42)
View Poll Results: Does your Rubbermount use too much oil (more than 1 QT. per 1,000 miles)
04- NO 199 20.82%
04- YES 42 4.39%
05- NO 224 23.43%
05- YES 42 4.39%
06- NO 222 23.22%
06- YES 23 2.41%
07- NO 89 9.31%
07- YES 7 0.73%
08- NO 57 5.96%
08- YES 7 0.73%
09- NO 10 1.05%
09- YES 0 0%
10- NO 10 1.05%
10- YES 0 0%
11- NO 1 0.10%
11- YES 1 0.10%
12- NO 11 1.15%
12- YES 0 0%
13- NO 2 0.21%
13- YES 1 0.10%
14- NO 8 0.84%
14- YES 0 0%
Voters: 956. You may not vote on this poll
Old 22nd August 2007
cantolina's Avatar
cantolina cantolina is offline
Luvs me an artsy chick...
Sportster/Buell Model: 883>1200 XLH
Sportster/Buell Year: 97
cantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant future
Default Rubbermount oil consumption poll
May have been one of these, but not this specific...
This is for RUBBERMOUNT OWNERS ONLY!!
I'm curious to see how widespread this problem is among our members.
The MOCO says anything up to 1 Qt. per 1000 miles is NORMAL.
We will not argue THAT point, for these purposes, let's just compare our experiences...
If yours DID, but has been fixed...VOTE YES for your year...
~Chuck
"entia non sunt multiplicanda praeter necessitatem"
Occam's Razor...
in English: "entities must not be multiplied beyond necessity."
My definition: "The simplest answers are the most likely"
~NRHS machined 1200 conversion, shittin and gettin...
XLF Tuning Stickies
Charging system troubleshooting
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
The MOCO says 1 qt/ 1000 mi. is normal because that is the INDUSTRY STANDARD. If you asked suzuki, toyota, honda, GM or any other company than they would give you exactly the same response.
2005 XL1200C
Those who trade liberty for security have neither.
unfiguroutable's Avatar
unfiguroutable unfiguroutable is offline
Sportster/Buell Model: XL883L
unfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the rough
Default 3 quarts
3 quarts come out every oil change and three go right back in. my oil level is perfect. i run the regular interval (5k) and use rev tech 20/50 oil in my stage 1 (minus heads) 05 low
LoyaltyRB
cantolina's Avatar
Well, there were two reasons I set up this poll....
One is this statement, from another thread:
Originally Posted by bmmccandless View Post
Here's the deal, the majority, probably 90% of the rubbermount engines are having oil issues
Later, he admits he's being a bit dramatic.... ....which is fine, but I believe the number is about the polar opposite...
Secondly, I'd like to know, for my own purposes, if this is or is not limited to 04/05 bikes....
You should have specified stock/stage 1 rubbermounts. Some conversions are having oil consumption problems and that seems to be at a much larger percentage than stock oil consumption.
Folkie Folkie is offline
My bike uses maybe ½ quart between oil changes every 5,000 miles.
Old 23rd August 2007
cantolina's Avatar
We've already had a poll about conversions and oil usage...
Not even sure stage 1 is an issue at ALL...(Stage 1 not to be confused with converted, right?...you mention both)
Depending on the results, maybe we'll narrow some things down later...when a good number of votes are in...
For right now, I'm just interested in the overall prevalence of the problem, and more specifically with regard to years..
I don't care if its an 883 or a 1200, what's been done to it, nothing...other than a problem existing (or having existed once) and the year....
BTW...if you vote yes...PLEASE elaborate...
buckhorns's Avatar
buckhorns buckhorns is offline
buckhorns
Sportster/Buell Model: xlh 1200
Sportster/Buell Model #2: 2000 XL1200
buckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura about
Stage I on my 06 1200C, and it used a quart between the 5000 and ,7500 mile oil changes. I don't run it too hard though. WOT once in a while, and run 70-80 on interstate, run easy in the twistys. I'm not complaining. Hope I never have to.
Am I Here ?
Where Was I ? Where Are My Meds ?
Don't worry about old age...it doesn't last long.
Piggy's Avatar
Piggy Piggy is offline
Other Motorcycle Model: Dyna Street Bob
Other Motorcycle Year: 2007
Piggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enough
05 883C
didn't use much oil at all when still an 883, used a quart every 500-600 miles after conversion to 1250.
Current bike: 07 Street Bob
V&H Short Shots, SE air cleaner, Power Commander, forward controls
Previous bike: 2005 Sporty NRHS 883/1250C conversion AKA oil guzzler R.I.P
cantolina's Avatar
Originally Posted by Piggy View Post
05 883C
Just out of curiosity, how many miles on it before the conversion?
