0 Coil polarity
Last Post: davesz1r
Last Post: smilinbrad
0 Top end failure
Last Post: Mission1
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
Last Post: The Doctor71
0 1998 883 spits and sputters at around 3000 rpm
Last Post: Tommr
0 Ground Up Beginner Build
0 clutch issue
Last Post: zack2267
Last Post: Billy1200
0 HD Museum Video - 1968 IH Dragster by Tom Reiser
Last Post: thefrenchowl
Last Post: Pagey
0 Valve keepers won't come out
Last Post: LLOYD883
0 Turtle tank on '79 frame
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 2009 883
0 "S" model specific Q&A
0 old style fender skirted
0 What's your road name? How did you get it.
Old 23rd March 2020
Tincan's Avatar
Tincan Tincan is offline
I refuse to suffer fools
Tincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to beholdTincan is a splendid one to behold
Default USA made Stainless hardware better than stock
I found a source of the highest quality stainless steel hardware. I purchased rotor hardware as well as a primary side screw kit and received them today. I am super satisfied with my order. These are not the fancy ass polished crap made in India or shit Colony chrome crap. I can't see paying for ARP unless its a critical part but these will never rust like chromed screws and bolts eventually do and are far superior to the stock harley parts.
After some comments in the thread I called the company and spoke with Joe who is the owner.
First off they are NOT a fastener company. They are a high end custom shop that builds custom engines. These are the parts they use in their own assembly of the engines. They merely have some bolt kits listed online.
All the fasteners are US made and 316 stainless suitable for marine applications (i.e. high corrosion resistance / fixable enough to endure high vibration)
http://vulcanworks.net
The company is in Manchester NH. I spoke on the phone with the owner Joe who was most helpful.
"WITHOUT DEVIATION FROM THE NORM THERE CAN BE NO PROGRESS" Frank Zappa
Old 23rd March 2020
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Not to be a "negative nelly" but as I understand it, stainless steel hardware (i.e. bolts and screws) are a lot more brittle than standard grade. With all the vibration a motorcycle has, stainless steel bolts are more likely to snap off than standard grades.
Old 23rd March 2020
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Depends on the grade, marine grade handles far worse conditions and vibration than bikes do. It comes down to production ethics in this case.
Old 24th March 2020
Toejam503's Avatar
So true, the stainless I've used in the past was always hit and miss. As long as Tincan got good quality he should be OK.
Old 24th March 2020
Whitewalls's Avatar
Sportster/Buell Year: 1971
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
Vulcan makes quality stuff. Their advance unit for early HD's is known to be the best you can buy.
Old 24th March 2020
Be careful where you choose to use Stainless Steel Bolts
"A common question is whether stainless steel is stronger that a grade 5 or grade 8 bolt. Stainless commonly comes in grades 18.8 (304) or T316. Stainless steel bolts are rated for corrosion resistance. Bolt strength is rated in PSI (pounds per square inch). A stainless steel bolt has the same PSI rating as a grade 5 bolt (125,000 PSI). A grade 8 bolt has a stronger rating with a PSI of 150,000."
https://www.nutsandbolts.com/v10-sta...eel-grade.html
"Stainless steel is an alloy of low carbon steel and chromium for enhanced corrosion characteristics. Stainless steel is highly corrosion resistant for the price. Because the anti-corrosive properties are inherent to the metal, it will not lose this resistance if scratched during installation or use.
It is a common misconception that stainless steel is stronger than regular steel. In fact, due to their low carbon content, many stainless steel alloys cannot be hardened through heat treatment. Therefore, when compared to regular steel, the stainless alloys used in bolts are slightly stronger than an un-hardened (grade 2) steel but significantly weaker than hardened steel fasteners. Unless great care is taken, stainless fasteners are susceptible to seizing up during installation, a phenomenon known as galling.
Most stainless steel fasteners are much less magnetic than regular steel fasteners though some grades will be slightly magnetic.
Stainless 18-8 - 18-8 refers to any stainless steel containing approximately 18% chromium and 8% nickel. This is the most common stainless designation for hardware. For information on 18-8 stainless steel material properties see our Material Grade Identification and Properties Chart.
Stainless 316 - A highly corrosion resistant grade of stainless steel. Ideal in salt water and chlorine environments. More expensive than 18-8.
Stainless 410 - A stainless alloy that is harder than 18-8 stainless steel, but not as resistant to corrosion."
https://www.boltdepot.com/fastener-i...materials.aspx
I'm sure the better grades of SS are quite expensive:
See: 410-HT & 416-HT Martensitic Stainless Steel-Hardened and Tempered
https://www.americanfastener.com/mec...ous-fasteners/
To Compare Steel Fasteners, see here:
https://www.americanfastener.com/ast...teel-fasteners
Old 24th March 2020
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Don't forget your anti-seize when using stainless fasteners. Ask me how I know.
Old 24th March 2020
Ireeman's Avatar
Asgardian
17-4 is medical grade, not bad in marine and rather strong.
Old 24th March 2020
ChinCactus's Avatar
Well now I now more than I ever did about SS hardware! Never knew what all those numbers signified 302, 316, 18-8, 17-4.
I prefer the look over that of chrome fasteners. I will have to check to see if I have them in and critical applications.
Old 24th March 2020
bill smith bill smith is offline
bill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to allbill smith is a name known to all
McMaster Carr has a good selection
