0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 "S" model specific Q&A
0 Ground Up Beginner Build
Last Post: Paul.W
0 Turbo Iron 883
Last Post: Cj_
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
Last Post: Bikeaholic
0 Info needed on mini sumps.
0 primary cover
Last Post: smoggy
Last Post: davesz1r
0 Chinese S&S carbs
0 oil transfer valve
0 Tappet blocks and tappets
0 Sportsterpedia Progress
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 2nd April 2020
BKB's Avatar
BKB BKB is offline
Default Diagnostic code ?
Went for a ride today. After riding 75 miles with no issues, I stopped for gas & half a mile from the restart, bike started losing power, popping & banging, & wouldn't idle. Had to go home for the trailer. Pulled the codes & what came up was... b1006 & b1007. Looked at the stickies on diagnostic codes & couldn't find these listed. Can any one tell me what these codes mean & what the cure is?
Old 2nd April 2020
BKB's Avatar
BKB BKB is offline
Oh, BTW, I disconnected the battery this morning & cleaned all the terminals, before I left on the ride. Could that have anything to do with the problem?
Old 2nd April 2020
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Overvoltage? Disconnect the alternator and/or regulator and see how it runs off just a (charged) battery?
Could be you disturbed something.
Old 2nd April 2020
BKB's Avatar
BKB BKB is offline
I'll try that tomorrow, Tom, if I can figure out what connectors to pull. I'll also try another battery that I'm sure is good. Thanks. The overvoltage codes were B1006 &7, in post #43 of the How does diag mode work thread. Mine came up b1006 &7.
Old 3rd April 2020
commando57 commando57 is offline
Sportster/Buell Year: 2016
Sportster/Buell Model #2: XL1200T
Sportster/Buell Year #2: 2017
Other Motorcycle Model: Z50A (Honda)
Other Motorcycle Year: 1969
commando57 is an unknown quantity at this point
Bad bunch of gas, maybe?
Old 3rd April 2020
shanneba shanneba is offline
DTC B1006 and B1007
The speedometer (XL) and tachometer (XR) monitors terminal
1 for ignition power, and terminal 6 for accessory power.
DTC B1006 is displayed when accessory line voltage is
greater than 16.0V for longer than 5 seconds.
DTC B1007 is displayed when ignition line voltage is
Test the charging system.
If it tests good the next step is clear the codes, run the engine at 3000 rpms for 5 seconds.
If the code(s) return replace the speedo (XL) or tach (XR)
I would check the speedo / tach wiring and connectors first
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 3rd April 2020
BKB's Avatar
BKB BKB is offline
shanneba, thanks. If the regulator or alternator has failed, can it cause the 16V thing? I know less than nothing about this electrical stuff. Can that also cause the backfiring & other stuff, too? commando57, just filled up the truck yesterday, at the same station that was built only 2 months ago. Truck's running fine. Don't think it's the gas.
Old 3rd April 2020
Dazed & Confused
Charge your battery. Follow the regulator wires. Disconnect its' connectors. It's a simple test.
Do you have a volt meter?
Old 3rd April 2020
Hippysmack's Avatar
If the regulator or alternator has failed, can it cause the 16V thing? Can that also cause the backfiring & other stuff, too? commando57, just filled up the truck yesterday, at the same station that was built only 2 months ago. Truck's running fine. Don't think it's the gas.
If the regulator is not fully grounded to the frame, you can overcharge your battery.
My stator went bad and what caused me to test it was that the bike ran out of power and then backfired and shut down.
I could fire it back up but it went dead again.
I was basically running off waning battery power.
Here is some simple testing for the stator and regulator below that.
http://www.sportsterpedia.com/doku.p...lternator_test
Old 3rd April 2020
sprink's Avatar
sprink sprink is offline
Sportster/Buell Model: 2004 XL1200R
Sportster/Buell Year: SOLD
Sportster/Buell Model #2: 2000 X-1 lightning
Sportster/Buell Year #2: SOLD
Other Motorcycle Model: XB1200XT "Uly"
Other Motorcycle Year: 2009
sprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond repute
Better call Paul !
