0 New battery
Last Post: gpydeski
Last Post: Four Speed
0 Carburetor 101 Float valve question
0 Been Sitting For 5-10 years; Starts, But Dies
0 Flat spot, help
Last Post: bill28
0 normal heat or overheating engine
Last Post: seajay
0 timing.
0 Need Help! (Bleeding Rear Brake)
Last Post: Encyber
0 I broke it! (77' electrical problems)
0 Silver solder my tank or just use a liner product?
Last Post: XLPIZZA
0 Mechanical regulator
Last Post: Beazer
0 Child Car Seats
Last Post: mesalkn
0 Thanks Hammer Performance!
0 ***DK Custom-Beat The Heat-Save 10% on Cooling Components***
0 I know I'm gonna catch flack for this...
Last Post: spoon
Last Post: chief100
0 Oil pump Iron 1000 1979 bizarre.....
0 Bator International Q
Last Post: Doc308
Last Post: AECS
Last Post: alaxjordan0
Bartman (55), suarezrh (44), Dash (38), x_Dj_x (37)
Old 17th August 2018
Kmanator Kmanator is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Yamaha XT600
Sportster/Buell Year #2: 1994
Other Motorcycle Model: Soft tail 96c.i. S&S
Kmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud ofKmanator has much to be proud of
Originally Posted by brianbbs67 View Post
How is the oiling of the primary chain done?
I will periodically squirt 90 wt oil on it just like the drive chain to the rear wheel.
Old 19th August 2018
StonesCycles StonesCycles is offline
Sportster/Buell Model: Xlch900
Sportster/Buell Year: 1971
StonesCycles is an unknown quantity at this point
[QUOTE=Kmanator;5695060]Thanks man!...The motor sprocket was the key to the puzzle for me as well to get the sporty 35 series 3 row chain to the big twin 428 series double row chain to connect to the big twin trans..What I did was mill down the sporty motor sprocket in to a "Hub' and then press fit with a .008" interference fit into a shovelhead compensator sprocket,After the offset was established it was welded together.For my build with the late model [Twincam]five speed trans I used a .500 offset final drive sprocket to get the sweet spot between the the motor sprocket,82 link primary chain and the final drive 530 non O ring chain.
Hell yeah man! That's going to be a huge help! Thank you. I'm stoked for mine. One of these days I'll post up a build thread for mine. I just finished the engine today.
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
I could be wrong, but that chain was made to run constantly thru an oil bath. The occasion it needs to be oiled is always. Maybe you could rig up a total loss oiler?
Ok, now I'm revived
Yes,Primary chain is a duplex vs.A roller chain like the rear...History shows they last approx 5000 miles running open,Rain being the culprit of the longevity.At $20 bucks a pop for a replacement I consider a new chain every season as a consumable.
Old 10th October 2018
Berniebuell Berniebuell is offline
Sportster/Buell Model: Sporster XLH
Berniebuell is an unknown quantity at this point
Default Divorced Ironhead Tranny
What would you guys recommend as the best/easiest big twin tranny to use with a divorced ironhead engine. I am in the early stages of ironhead with the tranny hacked off. Thanks
What is the best big twin tranny to use with a divorced tranny ironhead ? Range of years ?
Old 12th October 2018
A 4 speed kicker from a big twin non rubermount would be the most compact size-wize next would be a softtail 5 speed up to 1999 before the twincam motors[HD bolted the trans to the motor as a "Unit"] The softtail 5 speeds have better spline clutch basket shafts and superior electric starters.My build I used a 2002 Twincam Softtail 5 speed trans and cut the bolt flange off the trans case and got creative with the fastening system to bolt it to the adjustable trans plate that through bolts to the frame.I do have a Kicker Kit for this trans that will be installed @ final assembly.
Still making progress,,,Another set of bars and re-did the rear brake pedal correctly to "Pull" the brake shoe lever instead of the longer push pedal I had....
Here is a shot with the "Rabbit Ear" bars I made to try for the feel.
[url=https://imgflip.com/i/2h22q5]
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
Looking good!
Knees in the breeze.
Gamertag, PS4: Bikerdude__
khav's Avatar
khav khav is offline
Sportster/Buell Model: XLH Bobber
Sportster/Buell Year: 1979
Other Motorcycle Model: FLHTK
khav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant futurekhav has a brilliant future
Liking the new bars. I know that you've done a few custom iterations, but personally prefer the more traditional curve...runs a cleaner line from the forks which are a focal point. Awesome build.
Gold Member's Avatar
My favorite kind of bike. Next to my '72 that is.
- Marcus Aurelius
