0 Drag race wheel setups
0 Fat Bob tanks on a 93 Sportster
0 Air or Co2 shifters
0 Variable Pressure Clutch - VPC
0 23 years old just bought a 1980 XLH
Last Post: 60weight
0 Starter/solenoid issue
0 Best Bang for your Buck Exhaust option?
0 Wiring Diagram in autocad
0 72 metal shavings in oil?
Last Post: Scuba10jdl
0 heart attacks are rather painful
Last Post: Bwf347
0 Loose solenoid bolt
Last Post: spacecoast
0 Slip on muffler
0 Brake Problems
0 got pulled over the other day....
Last Post: goofyfoot2001
0 Metzeler Cruisetec
Last Post: Nora44
0 Ran out of gas.
0 Shoulder rotator cuff problems
0 Does titanium exhaust exist?
0 Belt keeps moving to the right, replace transmission sprocket
Last Post: RoelVP
leprechaun50 (69), Hammerhead (56), c.wissler (49), kjy026 (47), RoseLady (47), Jayjunior (42), hradek422 (31)
  #181
Old 16th October 2018
DirtyHarry68's Avatar
DirtyHarry68 DirtyHarry68 is offline
Sportster/Buell Model: 1968
DirtyHarry68 has disabled reputation
the double bearing drum is more rare.i didn't come out until 1967 for the electric start xlh.the single bearing was used from 1957 until '66 on both xlch and xlh.til 69 on ch only.
Good info, thanks. If I ever replace I’ll look out for the twin bearing one. For now I’ll try to salvage this one.
Grinding past made mince meat of the shim - I thought it would be harder than the drum, which is barely touched.
Oh well, fat chance it would have been even anyway, time for plan B.
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
right.the double bearing drum primary set-up won't fit under a tin primary cover.
Old 17th October 2018
Maybe that’s why my tin primary was eaten up, someone tried it. Nothing else I can put it down to so far.
Old 22nd October 2018
Worked on clutch hub this eve. Took off high spots, some marks visible as I didn’t want to take off too much. Then wrapped a strip of emery round it and took of any marks on the top surf. See how it goes, I can buy another when one comes up and I can afford it if necessary.
Old 25th October 2018
Clutch drum has been given the DR DICK treatment thanks to a friend with a machine shop
There are still some marks on the lower surface but I think it will work - beats my efforts anyway. The weird thing is that it was dry inside before even with the broken pin mess and 0.009 clearance.
nice.have you been able to source any new washers?
Old 26th October 2018
Like an idiot I bought a full set before I fully understood what I needed to do. Doing it this way you can pick any size washer you like and cut the upper surface where the ratchet gear sits to suit. Actually I wouldn’t buy variable size washers of any type again, just buy the thickest one and grind it to the size needed on the lathe in any other scenario (eg. trans).
i hear you.i still have a handful left over from my trans. upgrade.you calculate what you think you need order them,and it turns out to be something different.
Old 27th October 2018
I was thinking of back cutting the gear in place after riveting it on. Ideally I’d have the done this with the clutch gear out to test fit, but got carried away with the gearbox and it’s all back together now, so might make a dummy clutch gear shaft.
Any opinions?
