0 WTF Happened
0 Air Filter Soaks With Gas
0 Runs rough on highway.
Last Post: Rich L
0 Hoo rah for Missouri.
0 Lacing a 21 inch wheel to a 19 inch hub
0 stress killer
0 Spectro STL 75W140
Last Post: Tucsonmax1
5 Summer time heat
0 2 into 1 exhaust build
0 1981 ironhead xlh PROJECT
Last Post: owlsplace
0 Cv carb jet question
0 The Multi-tool thread
Last Post: khav
0 03 sportster front muffler Stud nut Thread size?
0 How do you upshift?
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: wrkdWS6
0 Do people notice your bike?
5 Why Are You Still Married?
Last Post: oupa
Last Post: gravydog
0 Floppy kickstand spring issue, 1991 model
Last Post: ReddTigger
Old 18th October 2018
dodgetrucken's Avatar
dodgetrucken dodgetrucken is offline
Sportster/Buell Model: xlh 900 custom
Sportster/Buell Year: 1964
dodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant future
Originally Posted by doodah man View Post
Be sure that you insist on .003” running clearance between cylinder and piston, if they try to suggest something tighter. My guy way back said he set the clearance to .0015, and everyone here agreed that was way too tight. You don’t want to stick a piston after it’s all put back together.
Awesome. I've been looking for that info.
Sent from my SM-N960U using Tapatalk
1st piston. I slid th pin out with my thumb after I PBed it.
2nd piston. Same with this pin as well. The brown on them is really old oil. I can take it off with my fingers.
doodah man's Avatar
that is a very interesting pair of oil rings. never seen them like that, i wonder if they are factory?
I'd say they are really. There's like 3 or 4 parts.
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
The Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant futureThe Doctor71 has a brilliant future
Those oil rings look like original factory 2 piece oil rings..... or at least they appear similar to what came installed on my '71 & '74.
IMHO, they are garbage..... I'd trash them at your first opportunity.
Replace 'em with a newer 3 piece oil ring..... from Hastings, for example.
Yeah like I said ar the beginning I planned on getting rid of the rings. I wasn't going to keep them what so u think about the pistons? Thanks for the heads up on the ring company.
doodah man's Avatar
+2 for hastings rings. those pistons are probably ok to put back in service, especially if your funds are tight.
Lol yeah there a little tight. It's my birthday this week & in Ohio u have to get tags for Vehicles but this year I have to get a new license as well. So 1 car, 1 truck, the bike & a new license. It's not going to be cheap. I Didn't think she would be down & out.found a site that had a set of std pistons I think.
Chuckthebeatertruck's Avatar
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
You guys make me smile some days, and that's not a dig!
Let's get this moving. BMI karts has brand new 900 cylinders for $50 a pair, gasket sets for $10. I just had a couple of sets delivered last Thursday.
Standard cast pistons with rings and clips are circa $100 from many vendors.
Oil rings are stock, these are called ladder rings. They work, but you will pass much more oil.
Check your rods for twist, the wear pattern is odd.
