0 Stacking the Alto Carbonite clutch !
Last Post: Bikeaholic
3 Shaky Dave Recovery
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 Finding an accessory power source
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
  #91
Old 17th November 2019
Post your dyno cuz I call bs.
You really need to call your therapist.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Oh, I see. You can dish it out, but you don't like it when someone calls you out, Huh?
Here's my untuned dyno and the one we did 2 weeks later after I fine tuned but more importantly fixed my crankcase breather hose and filter that was clogged up tight. Their printer didn't work but if you doubt my results so be it. Pretty much right on with Hammer's 1200 with cycleshacks and 570s. Better low and middle, slightly less up top.
Plug your breathers and run it to 6500 rpm a few times and do a pull. See what happens. I posted pics of my rocker cover gaskets literally blown out. The dyno operator said it felt like it ran out of compression or something around 5500 rpm. Still did almost 87ft.lbs. at 4400 rpm. My rear head gasket was weeping oil. The heat most likely warped the umbrella assembly because they were shot after that. As I recall, You blamed it on Hammer's cams in PMs you sent.
The dotted lines are with the krankvent I used to fix the problem. Ran without my air cleaner too.
Here's my untuned dyno and the one we did 2 weeks later...
When you draw in phony lines you should at least do it so the math works...
Cams with lots of overlap show the best, and worst, of what your exhaust is doing. The good and the bad.
I'm done, you're now on my ignore list. Something I should have done long ago.
When I get a 1275 kit installed (in the spring when my un-heated garage gets tolerable...) I'll start a new thread since 60Gunner so thoroughly and pointlessly trashed this one.
