Last Post: fafcpa
0 TC88A Programming Hardware
0 Ironhead in the uk
0 External breathing systems
0 Hi From Atlanta
0 Sportster Cobra seat
Last Post: duffy
2 My 1275 Hammer Conversion..
Last Post: Firehawk
0 H-D 2019 Financial Results
0 cam lobes
Last Post: Bow only
0 The B's Knees...
Last Post: shgrier
0 roadside belt change
0 77 XLCH oil line routing
0 Sleeve cylinders?
0 Hi from Spain!
0 Filling stock motor mounts with liquid urethane
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
bleed, brake, brake bleed, brakes, sportster
Old 13th August 2015
PheenX PheenX is offline
Sportster/Buell Model: XL 1200 Roadster
PheenX is an unknown quantity at this point
Exclamation Rear brakes won't bleed!
I just replaced the rear brake pads on my 2004 sportster XL 1200 R and in doing so found out there was air in the brake lines. So of course I decided to bleed them.
However the whole time I was pumping the brake and then holding it, I was unable to make any fluid flow through! I was wondering if anyone had any tips/advice? Would be much appreciated thanks.
rejeanprimeau's Avatar
Removed your MC tank's cap, press the brake pedal, if you see a geyser, you 're a new member of the MC teared rubber cup club. You should have open the bleeder before pushing in the piston. Buy a kit and rebuilt the master cylinder. You need a circlip plier to do the job.
I did open the bleeder before pushing in the piston, and I see no geyser, Nothingat all is happening really. Do I just have a ton of air in the lines maybe?
Fill up the tank, attach your pedal to a heavy thing, open the bleeder and let gravity fill your line. Usually take an hour.
Eric Von Zipper's Avatar
Eric Von Zipper Eric Von Zipper is offline
Sportster/Buell Model: C for Chrome
Eric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant future
I drained my entire brake system, and refilled it. it was a royal pain
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
You can use a vacuum to pull thru, or hang the caliper lower to let the bubble go up (helps to have the line loose too.
Last suggestion is to use a syringe and push fluid into the caliper. But this will tear the cup in the slave cylinder for sure if the stock cup.
http://xlforum.net/forums/showthread.php?t=842245
