Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > XL Forum How To Vids and Premier Download announcements
XL Forum How To Vids and Premier Download announcements This is where the How To videos will be announced and discussed. Other Premier Downloads will also be announced here.
Last Post: Blue Scoot
0 Idle / transfer ports Q
Last Post: Billy1200
0 What is the difference in the testing for Gasoline and Diesel engine oils?
0 Sonnax, Timken, Torrington
0 Photo bucket
Last Post: SLW210
0 Should I buy a Sportster??
Last Post: kkbii
0 Electric Kick-Starter 2004- up Dumbest Idea EVER
0 Ironhead 1000cc 1971 Help with clutch assembly
Last Post: Eworks-HD
0 "S" model specific Q&A
0 More PhotoBucket Horrors...
Last Post: SteveK
0 To hone or not to hone... that is the question
0 520 conversion for ironheads
0 Long intake
0 Which Battery?
Last Post: SLW210
0 Glyptal?
Last Post: Scott
Last Post: Bigshankhank
Last Post: spoon
0 Seat- New purchase or recover?
0 90" With an HSR45 Setup
Last Post: Bored now
Old 18th May 2006
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Default Front Brake Pad Change - Bert's How I Did It
My HOW I DID it video which shows how I changed my front brake pads is now available in the downloads section here: http://xlforum.net/vbportal/modules....warticle&id=47
I created a small video which is 25 MB and a large video which is 115 MB. They are both the same video.
I am calling this a HOW I DID IT video and not a How To video because this was the first time that I performed this job and I made some mistakes but I think it can still be a valuable tool for those attempting this the first time.
Also my video camera was messing up so the video is jumpy in some places.
At the end of the video I forgot to tell about replacing the master brake cylinder cover so if you use this video to help you perform this job please remember to put the cover back on.
Also I did not mention that you should put rags over the gas tank and under the master brake cylinder when you press the brake pistons back into the caliper. This is important because brake fluid can damage paint. Luckily the brake fluid that I spilled on the tank did not hurt the paint on the tank.
AMA #961454
Old 18th May 2006
Lucifer Lucifer is offline
Lucifer is an unknown quantity at this point
Don't know if I'll be able to watch the video because of modem a home but the rag around the master cylinder is a very good idea. Thanks Bert!
Dave
Ride to Live!
Old 8th June 2006
dave's Avatar
dave dave is offline
Other Motorcycle Model: FXDWG (Dyna Wide Glide)
dave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to behold
Nicely done Bert!
I'm surprised you didn't use any loctite on the caliper bolts. ?
Dave Funk: Lafayette, California. 2004 1200 Custom
Old 8th June 2006
bplinson's Avatar
The XL Forum Host
Should I have? Does anyone else?
Old 8th June 2006
indyrednek's Avatar
indyrednek indyrednek is offline
Sportster/Buell Model: 883c
Sportster/Buell Model #2: Flyrite Rigid completed?
indyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the rough
Not only no, but f NO!
Next time done it would have pulled all the threads with it.
Old 8th June 2006
dave's Avatar
I don't understand. Why would using loctite cause the threads to pull out?
Old 8th June 2006
avnsteve's Avatar
avnsteve avnsteve is offline
Sportster/Buell Model: nothing at the moment
Other Motorcycle Model: Honda CB360
Other Motorcycle Year: 1974
avnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura aboutavnsteve has a spectacular aura about
that's about what I was thinking...
also, did you address cleaning your pistons? once they've been exposed and get cruddy, they'll contaminate the caliper when you shove them back in, and possible ruin the seals which are glorified o-rings. Once those seals go bad, a person could experience brake lock up and or dragging I've had that problem on my goldwing.
Have a nice day :tour
Old 8th June 2006
indyrednek's Avatar
Loctite is used to lock something in place. It is not to be used on something that would be romoved on a regular basis.
The bolt is steel and the housing is aluminum.
The heat generated by braking would lock even the blue loctite in place.
I use antisieze on my threads.
I also work at an automotive dealership and have seen threads pulled from calipers and brackets at least once a week.
Old 8th June 2006
xena's Avatar
xena xena is offline
Assistant Administrator
Good job on the video Bert, thanks for posting it up!
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 12th September 2006
Kentucky Kentucky is offline
Sportster/Buell Model: XL1200RSC Roadster
Sportster/Buell Model #2: DT400B
Sportster/Buell Year #2: 76
Other Motorcycle Model: 04-FZ6, 06-350 Wolverine,
Kentucky has disabled reputation
If you look at or read the Sportster manual it tells you not to pull the caliper. I guess this was my first mistake. Not only did I pull them, I pushed the pistons back and never removed the master cylinder cover. Then, I cleaned the calipers with a mix of Simple Green, warm water and car wash soap. I also cleaned the pins, retainers and bolts. Now, everything looks brand new and the brakes work great. I don't use Loctite on anything when it comes to my brakes but I do use marine grade grease on the pins and threads...
