Keep & Kill
Snippets
22nd August 2019
Posts: 16 Sportster/Buell Model: Drag Bike Sportster/Buell Year: 1997
New Here, building drag bike with Buell M2
I am new here and haven't worked on a Sportster motor since the 1960s. I am building a Drag Bike using a 1997 Buell M2 (Sportster). Can someone identify the main differences in the Buell motor. I have the heads and barrels off and see Buell cast on the head and some obvious smoothing around the valve guides but not sure if it was done after the fact. it also has Andrews N6 cams. any tips are much appreciated.
22nd August 2019
Momentary Specialist
Posts: 877 Sportster/Buell Model: XL1200 Sportster/Buell Year: 1996 Other Motorcycle Model: ST1100 Other Motorcycle Year: 1999
I believe those bikes were stock with N6 spec cams. The heads should be lightning heads which have a 62cc chamber and aren't considered good performance heads. I haven't heard about any factory porting on them.
For more head information and photos go to Hammer Performance.
https://www.hammerperf.com/ttxlheads.shtml
You don't say what kind of drag racing?
22nd August 2019
A Million Facts & Figures
Posts: 10,248 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
The 1997 M2 had Lightning heads, which are really just a smaller chamber version of the standard XL1200 hemi head. The smaller chambers bump up the CR to about 10:1.
The flywheel assembly is also a Buell-specific piece and is slightly lighter than the Sportster version.
Other than those two things, it's identical to the 1997 Sportster motor. Same cams. Same pistons. Same everything.
The 1997 M2 motor was factory rated for 83hp, which is 70ish as measured at the rear wheel on a Dynojet. In addition to the increased compression and lighter flywheels, the Buell air cleaner and exhaust are part of the reason for that number being a big stronger than a stock Sportster of the day.
