3 Shaky Dave Recovery
Last Post: 1Scooter
0 1970 XLH 900 color?
0 Hi From Atlanta
Last Post: ZCarFan
0 Sleeve cylinders?
0 Options for SE a/c cover
Last Post: tussuck
Last Post: hexnut
Last Post: tussuck
0 TC88A Programming Hardware
0 Ironhead in the uk
0 External breathing systems
0 Sportster Cobra seat
Last Post: duffy
2 My 1275 Hammer Conversion..
Last Post: Firehawk
0 H-D 2019 Financial Results
0 cam lobes
Last Post: Bow only
0 The B's Knees...
Last Post: shgrier
0 roadside belt change
0 77 XLCH oil line routing
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
Old 8th November 2019
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
Default what gear oil do you use?
just wondering what gear box primary oil, people are using in there Sportsters & Buell when they are running a wet clutch?
thanks
2003 XL 88"
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Mobil 1 20W50 V Twin Syn, the same as my engine, for 9 years now.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
spectro heavy duty primary chaincase oil
Old 9th November 2019
thanks, Ibeen using Formula X,
been looking to change to Redline as I always ran Redline heavy Shockproof in big twins & was the best. but would not work with the primary. so looking to see if anyone using Redline oil in sporty Gear box & primary & what, they use.
motorend's Avatar
motorend motorend is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2019
Other Motorcycle Model: N/A
Other Motorcycle Year: N/A
motorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond repute
Had hd put the harley 80w140 in after they fixed my starter gasket leak.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
20w50 four stroke motorcycle oil. Same as the engine. Usually Mobil One or Royal Purple.
When I changed from whatever the P.O. had in the trans to Royal Purple, the clutch and shifting action were noticeably better.
(Not looking to debate oils... just answering the question)
Sleepy LaBeef (July 20, 1935 – December 26, 2019) RIP
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
I've been using Redline Gear (hypoid) Oil 75w-90 or 110 or 140.
Are you drag racing or did you just put this question in an odd thread?
If I was going drag racing I'd put Redline Type F Racing ATF in the trans/primary.
My R9T has Redline Heavy Shockproof in its' tranny and final drive. As you noted it's not suited to our Sportsters' common trans/primary.
Davo_137's Avatar
Davo_137 Davo_137 is offline
Hi Krash.
I’ve been using the Spectro stuff aswell. Seems ok so far.
Hey Tomcatt , I want to take my sporty to the track & bracket race when I can.
Hey Davo good to see you how is your XR1200?
Tomcatt I put the question in here as, lot of quick Sporty's was not sure if they ride them on street like me or just at the track.
but would be good to know the best sporty gear box & primary oil as my gear box has a mild back cut for shifting quick, like the twin cam carb dyna I used to have, I used the heavy shockproof in that. I'm wondering if the Redline Light shockproof might be the best oil to use? as thinking it being light could work with the clutch. hope someone knows as I can get that oil ok.
Davo_137's Avatar
XR looks a little different these days, set it up for touring, but I might set it up to do some more 1/4 mile stuff this summer, if the mood strikes.. getting abit hot for long trips up this way now and I’ve got a few ideas I want to try out at the track.
