0 73 XLH Total Power Loss
Last Post: Erikdowney18
0 Valve Lengths?
Last Post: motorhedmike
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
0 Cutting Out Cracking Popping, Etc, After Fully Warmed Up
Last Post: Rgm883
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
4th gear, 5th gear
Old 1st April 2019
Encyber Encyber is offline
Sportster/Buell Year #2: 2005
Encyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of lightEncyber is a glorious beacon of light
Default I can't drive forty-five
I know you know this.
I’m trying to get fully acquainted with my ‘05’ XL1200c after riding a Shadow VT1100 for more than 8 years. We’re getting along nicely, she and I, for the most part anyway, however there is a conflict. My ride to work (30 miles round trip) has a posted speed zone of 45mph most of the way and is staunchly patrolled and radar checked by local PD and sheriff’s deputies alike.
My problem is I don’t know what gear is best for sustained cruising between 45 & 50 mph (especially 50). It seems like 4th gear is too low for sustained 50 mph cruising, yet 5th gear seems a little high, especially with a strong headwind adding load to the windshield. The poor old girl just wants to giddy-up. Faster than 55 mph and I’m okay in 5th, but then I’m fair game for cops waiting on the side of the road with radar.
So my question is this, is 4th gear okay for the majority of the 15 mile trek one way when stuck in that horrid time-to-shift zone? I don’t have a tachometer so I can’t tell you what RPMs I’m spinning. Comments?
Old 1st April 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
I have an '06 1200 C and I run mine in 4th at the speeds you're describing. No tach but I've run it up to 70mph in 4th, before shifting to 5th when I'm in a hurry, so 45-50mph should be Ok in 4th, just takes a little getting used to.
Old 1st April 2019
Lukidj's Avatar
Lukidj Lukidj is offline
Lukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant futureLukidj has a brilliant future
45 at 4th
50 without wind - at 5th.
Just feel where your bike is smoothest.
1200N 28T pulley ,1275 Hammer kit, JACKHAMMER 570 cams, Rico05R based maps.TTS
Old 1st April 2019
ReddTigger's Avatar
I have the same problem, but your gearing is way low..
45 is typically between 2nd and 4rd.. if you're near 5th, you are probably well under what you should be.
These engines are like a buzzsaw. they unlike the big twins dont like to chug along.. they want to spin...
for my 1997 5th gear is typically for over 70
States I've Ridden in
71.3 hp 70.8 tq
Old 1st April 2019
I love the power band...
Your change in elevation will have something to do with the right choice along with the curvaceous nature of the roadway (and traffic)...
I rarely run 5th gear unless I'm on the highway doing a sustained 60+...
3rd gear sustained 40-45...
4th gear is most used ... 45-60 on my typical country roads...
Check The Sportsterpedia - The Best Kept Secret on the XLForum!
Old 1st April 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
45mph is definately not a 5th gear speed. Hell, neither is 55mph for that matter. I gotta be doing 60 before I'll hit 5th for any sustained speed.
Now running the gears up to hiway speed it's 65 before I'll hit 5th. Sometimes 70 if the old girl wants the cobwebs cleaned.
Old 1st April 2019
Kbetts's Avatar
Kbetts Kbetts is offline
Other Motorcycle Model: Kawasaki H1 Mach III
Other Motorcycle Year: 1969
Kbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond repute
Keep it in 4th. Maybe a throttle rocker will help too.
Two lane back roads at 55-60mph I often drive a long time before realizing I'm in 4th and drop it into 5th on long straights.
Unless you're doing a lot of corner work, the 1200 just doesn't care much if it's in 4th or 5th under 70mph, In my experience.
Old 1st April 2019
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Model: Sportster Superlow 1250
Sportster/Buell Year: 2014
hexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond repute
Yeah 45 in 4th works for me as well.
2014 Sportster Superlow, Hammer 1250, smash head work, 560 cams, S&S rockers and lifters. ported throttle body and intake,
Hammer crush air cleaner, Barnett clutch
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Progressive suspension front & rear
Old 2nd April 2019
running 45 in 4th should be no issue, listen to the engine and drive train. these machines do not like to be run 2k rpm with a load as the drive line will snatch.
i have it worst since i run int'l gearing but i can steady throttle do the 45 (in 5th) but that is it no slowing down nor speeding up without a shift. i am not stock however so that makes some diff.
what one could do is a slight pulley change to get more reduction and rpm so 5th isn't a bear.
Old 2nd April 2019
Thanks everyone. I'm glad to see across-the-board agreement for the most part. I was finding myself running up to 55 before shifting into 5th and then backing down to 50. Staying in 4th felt better, just wasn't sure prolonged cruising there was what the bike wanted. I failed to mentioned that I have a Screaming Eagle II package installed. Don't know if that matters.
