5 Terminology Sticky?
0 Hello from Murcia-SPAIN
Last Post: heyshott 81
Last Post: oupa
Last Post: Darkseacret
0 How to start a 1967 Sportster XLCH
Last Post: JackPrice53
0 XB9 crank?
Last Post: Curbside
0 Jutland 05-31-16
Last Post: slcharger
0 XR1200 belly pan on an XL?
Last Post: CT XR rider
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 And so it begins......
Last Post: Texassporty06
0 Spokes or Mags
Last Post: Desertfox
0 Spokes question
Last Post: Doc308
Last Post: Nayra
0 Fuel Pump Problems
6 Is Your SPORTSTER...
0 How stock is your bike
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
  #371
Old 22nd June 2012
04xl1200c's Avatar
04xl1200c 04xl1200c is offline
Bike Builder
Other Motorcycle Model: CB750k SOHC
Other Motorcycle Year: 1977
04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future
Originally Posted by Rico 05R View Post
Something like 4,0,6,0. That's as close as you'll get with those Twin Cam maps.
Why Rico said is right! The dtt people don't do anything or even build the unit for the sporty! The fact that they work is treated like an accident!!!!!!
So with that in mind use the settings that Rico said u should have"ok" luck my bike didn't like any combo.
I love my Samson Powerflow III 2-1 Exhaust
Old 22nd June 2012
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
I'd run the IT at 5 and the IA at 5.Try it, and adjust from there. Only change one at a time when testing. Find the extremes and shoot for the middle. You should hear the changes and feel it.
"Only Fools Celebrate A Fool"
Old 22nd June 2012
punkmxcn punkmxcn is offline
Sportster/Buell Model: xl
punkmxcn has disabled reputation
Right... I understand; if I remember correctly that' what I was told when I first built the motor a couple of years ago...
"LOUD, PROUD, AND PUNK!"
Old 22nd June 2012
Thanks, for the help guys... Fired right up!!! Happier than flies on shit!
Oregon here I come!
Old 22nd June 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
A Sportster engine configured like yours, needs a proper high compression Sportster map, not a modified Twin Cam map. The fact of the matter is, I wouldn't run any of the flash maps on that build if it were mine.
And just to echo what Dave said...Daytona doesn't know shit about Sportster mapping. That module was never designed with the Sportster in mind. It's only because of the work done by members of the XLForum that it is such a great addition to a carbed Rubbermount.
Old 22nd June 2012
rocketmangb's Avatar
We are Daytona's bastard step children !
Sure we only have 3 years of bikes but I bet more units are installed on Sporty's than Twinkies !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 22nd June 2012
I understand. Next week I'll ask for a proper high compression Sportster map.
6-0 it wouldn't fire... 4-0 it fired up strong! Thanks, Rico.
Old 22nd June 2012
Rico 05R's Avatar
JESTER SYNDICATE
No problem, have a safe trip north.
Old 22nd June 2012
I don't really want to get into a pissing match over the use of a custom map over the use of the canned maps in the module but.... the fact is, the canned maps work just fine if you have the switches set right. I've paid the price of admission, It aint rocket science.
Old 22nd June 2012
04xl1200c's Avatar
Bike Builder
I am not doubting you... Would u care to explain? Because my bike even on the settings everyone said would work would make my bike virtually unstartable it would back fire on startup and instantly start to ping. So I programmed a voodoo map and bam done! Bike runs great. My local Harley dealer won't install the tc88a on any sportster for the same problem I had with the canned map.
