0 Crankcase drain
Last Post: Andy Hog
0 71 XLH Value?
Last Post: JimVonBaden
0 The Strociek Project
Last Post: tkvalentine
0 sportster revival
0 Q cams in 73 xlh ??
Last Post: 73HEAD
0 Posting Pics
Last Post: BigAl57
7 2001 xlh 1200 off road
Last Post: Warlock
0 Allegheny National Park III
Last Post: Elzer0
0 Japanese Cush Drive!!
0 Canadian Purchases
Old 24th July 2021
Pappa G Pappa G is offline
Other Motorcycle Model: softail deluxe
Other Motorcycle Year: 2007
Pappa G is an unknown quantity at this point
Default primary chain adjuster install 1995 1200
bought a new style ( thicker bottom plate )primary chain adjuster, i don't know how to install it in the primary cover. the long bolt going thru the case won't turn to thread thru the cover. on the old one i was able to turn the long bolt to thread it out of the case.
Old 25th July 2021
Is the problem with alignment of the bolt (perpendicular) to the hole? Or a problem of the threads?
Take the locking nut off the old adjuster & see that it easily threads onto the new adjuster - To prove the threads on the new adjuster are the same pitch as the old one...
Then look at the threads of the hole in the case to be sure they are not damaged.
I believe there is a proper direction to place the adjuster in the cover - I believe the nylon cover is pressed onto the steel plate - The side from which it is pressed onto the steel plate should go toward the primary cover.
This should prevent that nylon cover, in an extreme case, from sliding off (not likely) into the primary cavity.
For Sportster Tech Info:
Old 25th July 2021
the long bolt threads thru the cover good with the nylon and the plate removed, its when the whole thing is in place that you can't turn the bolt thru the cover. if i loosen the top lock nut the bolt will turn and i can get the thing installed but the top nylon and plate are loose. 1995 xlh model
Old 25th July 2021
Pictures might help --- By your description, it sounds like an alignment (perpendicular) problem - but if it doesn't quite fit as expected...
Once you loosen the top nut & put the adjuster in place, can you wedge a screwdriver along side & against that top locking nut in order to hold it while tightening the bolt to it with the allen wrench??
Old 25th July 2021
I think # 3 the long bolt should turn freely with # 4 tightened down # 7 is a bushing that i think should let the long bolt turn freely when every thing is tightened down. i may have gotten a bad after market part? thanks for the replies
