0 Will a late model head('07) fit a '92 Sportster?
0 Idle / transfer ports Q
Last Post: Billy1200
0 90" With an HSR45 Setup
0 Glyptal?
Last Post: JonesL
0 Detachable Saddlebag Solution (pics, long thread)
Last Post: MrChris
0 External breathing systems
Last Post: Boil1337
Last Post: Lone Rider
Last Post: 72 Ironhead XLH
0 Buying and installing starter solenoid for '74.
Last Post: Greasyman
0 To hone or not to hone... that is the question
Last Post: duffy
0 Broken bolt holes/ mounts, can they be fixed?
Last Post: TheSporster
Last Post: 1skullster1
0 Seat- New purchase or recover?
Last Post: Kbetts
0 Long intake
Last Post: JonesL
0 Sonnax, Timken, Torrington
0 What is the difference in the testing for Gasoline and Diesel engine oils?
0 Photo bucket
Last Post: SLW210
Old 18th February 2013
Macky1986's Avatar
Macky1986 Macky1986 is offline
Sportster/Buell Model: 1980 IH Sportster XLH
Macky1986 is an unknown quantity at this point
Default Primary Cover Starter Shaft Needle Bearing
I just picked up a pretty nice primary cover off ebay. But with no needle bearing installed and not machined for it. What kinda of reamer do I need to do the machining? And what size?
gungatim's Avatar
gungatim gungatim is offline
Sportster/Buell Year: 79
Other Motorcycle Model: Yamaha TX500
Other Motorcycle Year: 74
gungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura about
If you are talking about the starter drive needle bearing, it is HD# 9063, or Torrington B-1210. Specs show 3/4" id, 1" od, 5/8" length. Is the cover you got for a kick only?
Nolite Te Bastardes Carborundorum!
Macky1986's Avatar
Yes, 9063. It does have the hole for the starter shaft , just not machined for it...I dont think its kick only, how would I tell?
gungatim's Avatar
I think I would just take the cover with the bearing in to a machine shop and have them ream it. They would have the right size reamers, and can make sure it is aligned correctly. Would be pretty tough to set that on a drill press and try to get the hole perpindicular to the mounting face without building some fancy jig.
I just assumed since it wasn't machined for the bearing that it was off a kick only bike.
Old 16th April 2013
Macky1986's Avatar
I ended up bringing the primary to a local guy who said he would do it. I went to install and when putting the cover on, the starter shaft gets stuck in the bearing...I told him about it and he said he would take out an thousands. Got it back and its better but I could see the starter being constantly engaged because the shaft is stuck in the bearing...now what???
Old 7th December 2019
MadMike_1126's Avatar
MadMike_1126 MadMike_1126 is offline
Sportster/Buell Model: Ironhead Sportster XLH
Sportster/Buell Model #2: 883 Custom with 1200 kit
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Softail Heritage 103"
Other Motorcycle Year: 2016
MadMike_1126 is an unknown quantity at this point
Default Did this ever work?
My 77 XLH was fine then stopped engaging the starter. I've replaced half of the starter assembly parts now and come to find there was no needle bearing or thrust washer on the primary case.. I ordered the parts but no way in hell this bearing will fit. Were you able to get your primary case machined to accept the bearing and work properly?
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
The shaft does remain in the cover, it just has to spin in the bearing
