0 Michelin Commander 3
Last Post: Sportyman13
0 A couple more noob questions
0 Momentary starter switch installation question
Last Post: Coz
0 Stock pipes
Last Post: Joe_jeep
0 Turbo Iron 883
Last Post: Joe_jeep
0 Michigan Thumb Run:
Last Post: Bow only
Last Post: Joe_jeep
0 Craigslist
0 Short Shots w/mid controls
0 Anyone around ENC, specifically wilmington - emerald isle
Last Post: RamblerAl
0 Tach/speedo
Last Post: Hornsmith
0 points/condenser
0 2004 ICM
Last Post: LLOYD883
0 Lifter / Tappet Please Gimme a Hand
0 How to long term storage?
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 too iron mick ,, new,bruce lee doc,, be water,,,,, espn 30 for 30,, can,t wait
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 Proper XLCH
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
Old 21st February 2020
TUCCI's Avatar
TUCCI TUCCI is offline
Sportster/Buell Year: 2016
TUCCI is an unknown quantity at this point
Default How tricky is it to replace dipstick trim from oil tank?
Could I get someone whose changed one of these out to give me a quick pointer on replacing it. I dont want to hamhock it and throw $20 out the window.....I appreciate it.
2016 ROADSTER
It snaps in and out, easy easy. If you’re concerned take the outer cover off the tank, turn it over and you will see the tabs that hold it in place.
rocketmangb's Avatar
Seems it has a push nut on the back side.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Yes, it does have a push but, it's no problem. Just pull the push nut off, then when you put the new trim in place, push the new push nut on.
I don't remember any tabs; I thought t was just the push nut that holds it in place?
Folkie
South East England Riders
I have a new one here some place
Folkie's Avatar
Brass Nut
I replaced my chrome one with the black one.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
When all else fails... read the instructions.
Remove right hand side cover (3) by gently prying bottom lip of cover off tab on oil tank. Lift cover up slightly so mounting holes (7) on top of cover clear mounting posts (8) on oil tank. Remove cover.
To remove bezel (4), remove the push nut (6). Press outward on the locating pin (5) on the inside of the bezel until the bezel separates from the side cover. Discard the push nut.
Press the new gloss black bezel (4) into position on the side cover (3), aligning the locating pin (5) with the small hole.
Secure the bezel with the new push nut (6) from the kit.
Place top of side cover onto right side of oil tank (2) so that mounting holes (7) in top of cover fit onto mounting posts (8) on oil tank.
Press bottom of side cover in place on oil tank so that slot in bottom of cover snaps onto mounting tab on oil tank.
https://serviceinfo.harley-davidson....5?locale=en_US
Should only be 2 hrs labor at your local dealer...
Folkie's Avatar
Brass Nut
That's a bit extreme!
But, OK, I'll go with it.
Old 22nd February 2020
TUCCI's Avatar
Thanks for the details ...that's what it looked like from what I can see...appreciate it 👍
Folkie's Avatar
Brass Nut
Or 5 mins max if you do it yourself.
