0 wavers
Last Post: ronccc
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
0 1275 Hammer Kit Died
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Rear wheel alignment
0 Basket case
Last Post: bill smith
8 Crankshaft Failure
0 Cv carb jetting
0 Buell Blast headlight compatibility
Last Post: apotheon
0 Down on oil
Last Post: Billy1200
0 Tappet Block Cover Logo - Recognize?
Last Post: canoli
0 Coil Resistance Question
0 900cc Cylinders
Last Post: Nitro57xl
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
primary dipstick
Old 1st July 2020
Folkie Folkie is offline
There is an inspection cover on the bike with only 2 screws used just to insect the oil level, you do not need to take off the derby cover to do so.
Inspection cover with two screws? Do you mean the chain inspection cover?
Old 2nd July 2020
NLXL's Avatar
NLXL NLXL is offline
Originally Posted by juzyHD View Post
4 speeders have inspection screw for primary fluid level. I was thinking to cut a bigger hole and screw an inspection window in. For later models it could be done same way, it just be neded to cut it on right height.
So does the 1991-1993 5 speed models.
But...not a bad idea. Something like this:
https://afepower.com/afe-power-46-00...el-sight-glass
Sportsterpedia
Objects in mirror are shaking less than they appear
Old 2nd July 2020
juzyHD's Avatar
juzyHD juzyHD is offline
Master Bike Builder
Sportster/Buell Model: sportster 1200
Sportster/Buell Year: 1986
juzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond repute
But is low primary fluid an issue where you need to regularly check on the level between fluid changes?
I belive it's not often, but I had an issue with this... and I'm not sure at the moment, that I solved it a 100%.
It was escaping into the engine. I changed the crank seal, but I think there is still some small migration. In this case it would be very handy to have an inspection window...
