0 Only one breather bolt breathing?
0 ELectrical Issue 96 xl1200s
0 1981 XLH Getting Recranked
Last Post: owlsplace
0 Clutch biting point
0 81 sporty 4 speed install ?s
Last Post: class of 82
0 Fork Gaiters
Last Post: 72 Ironhead XLH
0 Clutch Spring plate poll
Last Post: Sportster25
Last Post: sprink
0 Gas Cap problem?
Last Post: Kzac
0 Regulator contacts welding shut
Last Post: Kzac
0 2002 883 Fuel Valve repair kit
0 Top end tapping products
Last Post: Sportyheizer
0 primary chain adjustment
0 pop's through carb at,idle
0 Where is the oil plug on the cases? 77xlh
0 Rubbermount Poll
0 Harley's EITMS: What Is It & How Does It Work???
0 Help identify these parts
obinella (80), bathscum2 (70), XL883 (70), sammyson (68), mrscantolina (57), colonelangus (57), 5oh (54), black051200 (49), garagechoppe (49)
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud of
I have a National with the quick release hardware that I tried on my '77 XLT. Didn't like the turbulence around my head and tried both high and low adjustments of the screen, to no avail. Removed it and it's collecting dust. Also didn't like the way the screen affected the handlebars in gusts and truck passings.
Eric
ZTatZAU's Avatar
ZTatZAU ZTatZAU is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: '89 GL1500 & '71 CB750
Other Motorcycle Year: ^^^^
ZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond repute
Eric
Thanks for the additional feedback on the National Shield Eric! Do you remember the model name of your National? Do you normally wear a helmet?
ZT
PS: I sent you a PM!
Old 6 Days Ago
ZTatZAU's Avatar
Monte!
Originally Posted by Monte03 View Post
Several ways to skin a cat, Consider an HJC 3/4 Helmet with flip up shield, you can ride 60 mph all day long, IF you go with a Shield, make sure it has the adjustable mounts , up or down even by an inch can make a difference in Wind Buffering, ride it to test, adjust as needed
Is this HJC IS-Cruiser Helmet (that HJC calls a 1/2 helmet), the "HJC 3/4 Helmet with flip up shield" that you mentioned?
PLMK! ZT
Old 6 Days Ago
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: 1966 XLCH
Other Motorcycle Model: BMW Twin
Other Motorcycle Year: 82
Monte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud of
I have the older and newer versions of the HJC i30 3/4 helmet with a fuller shield than what you pictured , also has open / close vents
Cycle World Oct 1962:
'The Sportster XLCH is not every Man's cup of tea - and we don't think it was intended as such'
Old 6 Days Ago
ZTatZAU's Avatar
Thanks for your reply Monte! There sure are a lot of choices out there.
ZT
Old 4 Days Ago
Yes, I wear a modular helmet due to state law. I found the turbulence unsettling, but then I've been riding for nearly 55 years without a windshield. I don't remember the National model since it was about 10 years ago since I purchased it.
Sent pics to your email.
Old 3 Days Ago
ZTatZAU's Avatar
Thanks Eric! I appreciate the email and pics!
ZT
