Last Post: JonesL
0 1968 Vin number help
0 Starting issues (No Spark)
0 Stock 1200 or Converted 883 to 1250/1275?
Last Post: Turbo Sporty 48
0 Sprung two person banana style seat
0 Voltage Regulator
0 Mid West Meet & Greet
0 anyone recognize these pistons?
0 WTB saddlebags
0 Carb debate bendix zenith vs s&s super e???
0 Do people notice your bike?
Last Post: Bikeaholic
0 Swingarm bearings?
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
Last Post: duffy
0 Security system pagers
0 07 1200 heads or stock 883
0 Recommended Keihin Jet Sizes ? - 100% Stock XLCR
0 No caliper piston compression
Last Post: mwXL 2006
0 Another from the Phoenix area
0 Phoenix AZ
Last Post: GorilladaHun
OKsporty (67), humpbackbob (66), Sunnydazepleaze (58), dvsxtc (55), elmo (43)
Old 10th October 2019
Bmg17a1 Bmg17a1 is offline
Sportster/Buell Year: 65
Bmg17a1 is an unknown quantity at this point
Default '65 xlch mag question....
Does the helical drive gear have a specific location on the shaft relative to the point cam and rotor?
Installed a Hunt rotor that never had the gear on the rotor shaft and copied or approximated the placement of the pin hole from the old rotor and drilled it.
Given the wide latitude for adjusting the timing it seems that it would not matter.
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I wouldn't think it would matter as it could be adjusted out, if it even needed to be.
Ok, now I'm revived
