Last Post: lucifer_mr2
0 HAMMERPerf 90" In the Works
0 Range With EFI 3.3 Gal Tank
0 1967 XLCH stroker project
Last Post: barefoot
0 More of a reintroduction
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: brianbbs67
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Bars on C Riser?
0 The norse Saga's, or Pia & Tores ramblings if you like.
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Cylinder Piston kits
Last Post: Dave L
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
0 81 ironhead gear oil large leak
Last Post: Slidesquad24
0 oil cooler or not?
Last Post: Tucsonmax1
0 Trade Chrome for Black?
Last Post: Piglet
Last Post: lugster
  #5041
Old 3 Days Ago
T^2's Avatar
T^2 T^2 is offline
T^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to beholdT^2 is a splendid one to behold
Serviced, cleaned and put new tires on. Not necessarily in that order...
Old 3 Days Ago
cotton1's Avatar
cotton1 cotton1 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: XLH 883
Sportster/Buell Year #2: 1998
cotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond repute
Today I rode 230 miles on this sporty:
to pick up some custom made parts for this one:
My friend machined the parts for me for free. Cause he is cool like that.
Sometimes life ain't too bad
Cotton1
Old 1 Day Ago
lo-rider's Avatar
lo-rider lo-rider is online now
Sportster/Buell Model: 883C(1200)
lo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of lightlo-rider is a glorious beacon of light
Since the last post I got the Tour-Pak mount welded, polished and installed; bored the mounting holes in the Tour-Pak and ordered the mounting isolators; installed the saddlebag mounts, including turning some stainless spacers on the lathe; relocated the rear turn signals; installed the new rear fender and tail light; installed the mufflers and sprocket cover; reinstalled the rear wheel and belt guard; mounted the left highway peg.
Had to pickup the Snap-On tool (and learn how to use it!) for removing the pins in the tail light and turn signal cables.
BTW the seat, which I had to shorten in the front. is off a different model Sportster.
Old 2 Hours Ago
lo-rider's Avatar
Made an alignment tool and did the wheel alignment; adjusted the belt tension; installed the shift lever, right highway peg and saddlebags; fabricated and installed the vibration isolators for the Tour-Pak, and attached to the Tour-Pak the reflectors I had removed from the new fender.
Old 2 Hours Ago
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Finally finished installing a Mikuni HSR42 and seem to be getting it dialed in fairly well. I don't know how to describe the difference except that it's fun, the time between third and fourth got a lot shorter. I think my bike has sort of evolved into a sleeper.
You can't keep a good man down......... unless you tie weights to his ankles.
Old 11 Minutes Ago
lucifer_mr2 lucifer_mr2 is online now
Sportster/Buell Year: 2012
lucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant future
Went for a little ride in the local mountain road. Had fun and checked saw a local photographer. If any of his pics came out good, I might buy one. Although they do cost $25 a shot.
One bit I love about it there is the other riders. Having them say how Harley's are slow, but you can't throw them around, then chasing them through the tightest bits. And the new Hammer engine conversion lets me hold them on the straights, hich I had truble with the stock 1200 kit.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
lo-rider, blumtnman
