Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Engine Conversions
5 Why Are You Still Married?
Last Post: Flowerpunk
0 Floppy kickstand spring issue, 1991 model
Last Post: Sadsack
0 Project Strociek
Last Post: chevelle
0 What is the best '70's Ironhead to restore
0 WTF Happened
Last Post: Wilkinson949
0 Runs rough on highway.
0 900 dual carb front head
0 A Day in the Life...
0 2 into 1 exhaust build
0 hi from anchorage AK
0 If You Have An '04+ (Buell's too), Please Read (Oil Usuage)
Last Post: JaKaL
0 Mainshaft bearing
Last Post: CDeckner
Last Post: 83XLX
0 A different Oil filter test
Last Post: Airbozo
Last Post: wrkdWS6
Last Post: Eddie Lives On
Last Post: 83XLX
0 The Multi-tool thread
Last Post: Bassel
Last Post: 83XLX
Old 6th October 2016
Confused89's Avatar
Confused89 Confused89 is offline
Sportster/Buell Model: Had a 1200 XL
Other Motorcycle Model: FLHTP Electra Glide
Other Motorcycle Year: 2011
Confused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud of
Default Buell XB9 Conversion?
I have been looking at the XB9 bikes and I come back to the same question. Can you put a 1250 kit on these? The stroke is shorter. Would the bottom of piston hit the crank? IS the only option to swap out the crank on them?
I am that socially awkward moment.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
They're kinda a fun motor as is, would be a shame to change that just to make what everyone else already has.
Confused89's Avatar
Yes they are but I have an idea that I want to accomplish. It is still a few years down the road and will take a lot of engine work to accomplish. Just a personal goal that I want to accomplish.
Sleeper Sleeper is offline
Sportster/Buell Model: XL883R
They do make a big bore kit for the XB9. I don't know if they use the same exact pistons as the 1250cc kit or not. The piston diameter the is the same, the piston height??? I highly doubt you'd need to do any more than the top end though.
Personally I think it would be a cool project but I don't know anyone who's done it.
Displacement would be around 1050cc so the XB12 would still have the displacement advantage but I'd imagine you could rev the bored out XB9 a little farther.
Dirty Old Dog
Confused89's Avatar
Good point Sleeper. I found one in my area for a good price but first I need to get a few of my other projects done first. Looks like I will be getting one before summer of next year.
That's cool. Should be a fun bike to ride even left stock. I have a buddy who had one years ago and he still talks about that bike today.
Old 8th October 2016
Crash7557's Avatar
Crash7557 Crash7557 is offline
Other Motorcycle Model: HD Sprint SS-250
Other Motorcycle Year: 1967
Crash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond repute
XB9 has the same 3.5in bore as in a 1200 sportster.
The stroke is shorter on the XB9 (3.25in vs 3.81in) but with the same size stack so the pistons shouldn't contact anything at all.
"I love the mechanicalness of it"-Indian Larry
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
The XB9 shares the same bore size and piston compression height as the 1200's. However, since the displacement is smaller due to the shorter stroke, it needs more piston dome to achieve a given compression ratio. So it's not just a matter of bolting on a 1250 kit and having 1050cc instead of 1250cc. It takes a special piston. We stock them. The cylinder is identical.
Speaking of "1050 kit", that's a really misleading name. The 1250 kit's 3-9/16 bore (3.563) only nets out to 1021cc when you put it over the 3-1/8 stroke of the XB9's crank. I got no problem with a little rounding up, all the companies do it, but 29cc seems excessive to me. I didn't name the thing though, and we're kind of stuck with it since the other companies call it this. If we give it a more honest name, people tend to assume it actually IS smaller, which it's not.
We could do the 3.600 bore of the 1275 with our special steel lined cylinder, and that would net out to 1042.5cc. Maybe we'll do that and call it a 1050. That'd be more reasonable. We haven't developed the piston for that application yet, but it's not hard.
The Buell stuff in general though is very low volume and getting lower all the time. So when it comes to making new investments in market offerings, it's pretty far down the list. Still, though, if we can leverage off the Sportster stuff and do it easily, there's no reason not to.
Click Here to Contact Me
Old 9th October 2016
Confused89's Avatar
With heads that have the "best" work done to them and the 1021 kit installed with cams what kind of power would be expected. I know that temp and altitude makes a difference but a ballpark figure?
Old 31st October 2016
Confused89's Avatar
I went and did it. I found an XB9 for cheap and then I lowballed him an offer and he accepted that. I exchange money Tuesday with him for the bike. I already looked at it. It has the normal rocker box gasket leaks. 14k miles on it. I'll get pictures up here on wed.
