Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Custom Finishing
0 Only one breather bolt breathing?
0 3rd Gear another Nuetral
Last Post: Murph
0 VSS update...
0 Start Button not Working
0 now this is what racin is all about
Last Post: CMCSSeabee
0 Cam lobe to main brg race clearance
0 Short in the turn signals, opened it up, brass fell out?
0 Steering stem too short for tapered bearings, convert to balls?
0 rear tire fused to rim
0 Bike vs Bugs
5 swapping 35mm to 33.4 complete
Last Post: 73HEAD
0 Allegheny National Park III
0 2004 Harley Davidson Sportster (XL1200C) Custom (SportsTour)
0 Decade Long Project
Last Post: Cyclone14
0 Model H and DR DICK, Weekend Shop Videos
0 Front Brake Pads
0 What kind of brake disk to get
Last Post: Stray Cat
0 100HP @ 5000rpm 1250 build thread
0 Instrument of Expression, the next chapter of the Sportster legacy
Last Post: Woody9225
12 Remember the Fallen
0 When do codes clear?...
Last Post: kuch73
0 howdy
0 Cracks in brake disk
Last Post: lehel
0 Fork Gaiters
Last Post: tiderider
DAKSY (70), dwagar (70), DaveDuff (61), chaserband (59), bigcraig74 (48)
asv, brake, buell, clutch, lever
Old 5th August 2014
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
Default New levers (and perches and M/C)
Duc 999 Brembo 19mm radial M/C, reservoir, and billet cap, ZX6R clutch perch, and appropriate ASV levers to fit each everything picked up used on eBay for about $180.
Dash is also custom, made out of an old Maverick carbon fiber hamcam cover, with Sunpro gauges. Only the volmeter is hooked up as of yet due to lack of time. Clip ons are Westek billet clipons with billet handlebars, but the PO chopped the ends and welded 7/8" bar to convert to S1 controls. Left bar is slightly tweaked and they are ugly so I have some 1" buckhorns and 7/8" bar stock that I will be cutting and welding up to make new bars, which will also be about 1" taller. Mirrors are XBR with de-arched stems.
Love is the never-ending act of forgiveness - Peter Ustinov
