0 primary chain adjustment
0 Mid or forward controls.
Last Post: Bigshankhank
0 Helmet poll
0 How to jumpstart a motorcycle
0 Did something silly maybe?
Last Post: 11B40
0 Scorpion battery
0 2007 1200 low idle when hot...
Last Post: kuch73
10 Future hardtail springer.
Last Post: Andy Hog
0 Clutch Stud Spacer: 1.530" pn #5995, 0.040" #5996, 0.080" #5997
Last Post: XLXLXL
0 Steering stem too short for tapered bearings, convert to balls?
0 ***DK Custom-2 NEW Contests-Instagram & Twitter***
Last Post: hannamontana
0 Top end tapping products
Last Post: RandallM
0 S1 Buell chop
Last Post: joezx10r
0 What oil temp do you run
0 BEST LONG CHROME fILTER FOR 2001 EVO sPORTSTER
Last Post: FiftySixer
0 Hand brake for rear drum
0 Oh deer
0 04-06 metal oil tank
Last Post: BestCoastXL
0 Can't install pushrod cover
0 6 month old battery discharged and now won't charge at all
Last Post: adri
0 Short in the turn signals, opened it up, brass fell out?
Last Post: Debute23
SoCal 1200N (61), riverar7 (57), rx3732 (48), gnrxl2002 (44)
5 speed, 883, harley davidson 1999, installation, transmission
Old 16th October 2021
Ron Bizzle Ron Bizzle is offline
Sportster/Buell Model: 1200cc Sportster
Sportster/Buell Year: 1989
Ron Bizzle is an unknown quantity at this point
Default harley davidson 1999 883 5 speed transmission installation
I am in the process of installing a 5 speed transmission....all new to me as I have not done this type of work on a motorcycle before.....so I need all the help I can get.....video links, photos and all suggestions will be much appreciated.
Default 883 5 speed transmission installation
https://youtu.be/YKs59eW-qJ0
https://youtu.be/NHA9iw6V-Is
https://youtu.be/Fw-iwYs1tNs
https://youtu.be/NT_MxPOHw5w
https://youtu.be/pYtO2jj6MFs
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
Do yourself a favor and buy a factory service manual. They are expensive but well worth it, the best by far I have used in 40 years of amateur MC wrenching on various makes.
I have a Haynes Service manual but it a piece of crap.....I appreciate your advice.
Hippysmack's Avatar
Installing the assembly or assembling the tranny?
There is pics and advice in the Sportsterpedia if it helps any.
http://www.sportsterpedia.com/doku.p...:ref:svcproc11
Do you have specific questions?
Installing the assembly.....thanks for the link.
Hippysmack's Avatar
If you have the assembly ready to go in, it simply slides into the main and countershaft bearings then the 4 bolts on the trapdoor.
Assembly lube on the gears / shafts before going in.
No gasket on the trapdoor.
Did you take it out?
I am going to take out the old trans today.....I been reading forums and watching videos so I can get a better idea of what the process is going to be....you just brought to my attention "lube on the gears"... so this was just another very useful tip. I been stuck on trying to figure out how to adjust gear shifter. Don't want take it apart again once I get the cover back on...
I believe the following video will be very useful to this process:
ChinCactus's Avatar
It is really pretty easy. I did it and never had been into a trans before. I had bearings to replace that required some specific tools but I got it back together and it has been working fine since.
Also, IMO today's Chilton and Haynes manuals suck. They are ok in addition to a factory service manual but not in place of one.
Good luck. You CAN do this.
Hippysmack's Avatar
Take plenty of pics as you dis-assemble whether you post them or not.
That may help to solve questions later on assembly.
Post any questions here as you go about it.
Yes, you can do this. And we'll help as much as possible.
