0 Newbie from the UK
0 Sportsters No More?
Last Post: ARJ
0 Ugh the old girl is fighting back
Last Post: 79Harleydavidson
0 Rocker box
Last Post: Lube job
0 Ironhead Exhaust Poll
0 dragging a parachute
0 Do you blow dry your ride after wash
0 Carb tuning
Last Post: piratemike
Last Post: Daddio
0 top end
Last Post: Whitewalls
0 05 Roadster motors
0 Well... it kinda.... works.
0 Piston Hit Intake Valve
0 575 cams clearance issues?
0 Breaking News: Northerner terrifies Londoners
0 1999 1200S Sport ignition
0 2002 convert ignition for dual port heads
Last Post: CCC
0 Flywheel washer - material/part number
0 Sportsterpedia Progress
Last Post: Brad
jscibello (69), Reign (62), corad (58), desertratguy2001 (57), giggsbryan97 (46), gdice1 (43), judas (39), schruddy (37), Wrong Way (34), Crank
  #791
Old 5th March 2021
I too had problems and replaced crank position sensors. That being said I suspect that many good ones get changed out. I have learned that cleaning the harness connector, located under the engine between the frame rails, can restore good function without replacing the unit.
I.B.A.#26543,
Old 5th March 2021
I changed mine out "just because" but I kept the original in a parts box as a spare "just in case". I think maybe I'm a hoarder.
Old 5th March 2021
rejeanprimeau's Avatar
Originally Posted by Andym View Post
I'm sure HD outsourced the part and an aftermarket one may be fine. I just don't know. My thinking is to go with HD. I usually call the dealer and ask for the part. if you have the part number that is better yet. Today most dealers don't stock parts for older bikes, but they can get them. So I order the part and wait. It takes a few days to a week to pick up the part. I replaced the CKP sensors on two 2006 HD sportsters I own. The original ones seem to fail around 2-3K mileage. All good since. HD P/N 32707-01C. Cost was about $58 each.
I heard the dealer use Amazon more often than we can imagine.
They just print a sticker and the installation and make more money than dealing with the moco.
Old 6th March 2021
bobberman66's Avatar
bobberman66 bobberman66 is offline
Sportster/Buell Model: XL883C - Two Tone Blue
Other Motorcycle Model: Honda CM400T
Other Motorcycle Year: 1980
bobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the rough
If the aftermarket part is reliable, of quality construction and cheaper price. I would go with that. It’s convenient because it’ll be delivered to your door and Amazon’s return policy is pretty decent to. If you have the means to test the one you have to make sure that it’s faulty or not. That would be a good place to start. Cleaning electrical connectors is always a good practice. Forgive me if you covered that earlier in this thread.
Remember rubber side, down!
Wrench Head of the Popes of Hell MC
