0 Newbie from the UK
Last Post: hotrodbiker
0 Rocker box
Last Post: rubine
0 Sportsters No More?
0 Ugh the old girl is fighting back
Last Post: 79Harleydavidson
0 Ironhead Exhaust Poll
0 dragging a parachute
0 Do you blow dry your ride after wash
0 Carb tuning
Last Post: piratemike
Last Post: Daddio
0 top end
Last Post: Whitewalls
0 05 Roadster motors
0 Well... it kinda.... works.
0 Piston Hit Intake Valve
0 575 cams clearance issues?
0 Breaking News: Northerner terrifies Londoners
0 1999 1200S Sport ignition
0 2002 convert ignition for dual port heads
Last Post: CCC
0 Flywheel washer - material/part number
0 Sportsterpedia Progress
Last Post: Brad
jscibello (69), Reign (62), corad (58), desertratguy2001 (57), giggsbryan97 (46), gdice1 (43), judas (39), schruddy (37), Wrong Way (34), Crank
View Poll Results: Do you run with a headlight modulator?
Yes - being seen is being safe. 46 26.90%
No - I don't need no stinkin' headlight modulator. 69 40.35%
What's a headlight modulator? 56 32.75%
Voters: 171. You may not vote on this poll
  #111
Old 22nd September 2018
Yep, pretending you have a target on your back helps, oh, and that you are invisible.
I.B.A.#26543,
Old 11th March 2020
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond repute
I'd be scared that if my headlight flashed like that ...Depends onto speed of the flash I suppose, that people might see it as a Flash of the headlight indicating that you are signalling them to pull out..you are flashing them to let them out of a junction.
Old 6th March 2021
rejeanprimeau's Avatar
A police gave a 48 hours warning to a guy to have his headlight fixed.
He try to explain it was a modulated light but, the Leo said you have a broken wire and fix it.
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud of
A long time ago I rode with a guy who had a modulator. People would suddenly hit their brakes on a regular basis.
I was in my truck on my way to work and did the same thing. The modulation made me reflexively think "cop."
I would rather not be anywhere near the things.
Sent from my Moto E (4) using Tapatalk
kitabel kitabel is online now
Sportster/Buell Year: 1989
The basis was a NHTSA study from 60 years ago, done by Greyhound. They had a large number of counter-intuitive wrecks (car pulls out in front of bus) explained as "I didn't see that 80 foot long, 15 foot high box with the lights all over it".
They borrowed a trick from the rail service: a device that swivels the headlight in a tight arc (called a "Mars lamp"), which instantly draws the eye to the giant locomotive they didn't see a minute ago.
Blinking the headlight at 2-3 per second is too slow and not noticed. 7-8 is seen as continuously on. 4-5 is the magic number, and had a huge effect in reducing the number of collisions.
The important thing is not what people think it is, it's the fact that they know you're there.
