Snippets
28th March 2023
Posts: 280 Sportster/Buell Model: XL2 883 Sportster/Buell Year: 1994
28th March 2023
29th March 2023
29th March 2023
29th March 2023
30th March 2023
30th March 2023
31st March 2023
MetalWorkingXLFan
Posts: 732 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: KHK Sportster/Buell Year #2: 1954 Other Motorcycle Model: Valkyrie Other Motorcycle Year: 97
Originally Posted by cal43
I had a ‘71 Series II 88 that ate its timing chain.
I took it down to the frame and adapted a factory new low compression Ford 289 short block with 302 Mustang heads, a Holley 650 Spreadbore and dual exhaust Thrush side pipes.
4 speed top loader from a Torino grafted to a Dana transfer case and a Warn Overdrive. Hurst shifter. 16 forward speeds with 4 reverse.
8 synchro high, 8 synchro low.
This was in ‘76 and had no pollution controls. Registration as a farm vehicle and didn’t have to go through NJ DMV inspection.😅
It would beat showroom Corvettes to 85 and then get really unstable with that short wheel base and 32” tires.
Sadly, I messed up building my hydraulic clutch mechanism out of aluminum. After about 65k miles and a harsh NJ winter, galvanic action between it and the steel frame caused excess corrosion and the frame broke going over a set of railroad tracks.
I still have the intact trans combo out in my shop. The rest went to a restoration outfit for parts.
It ran so effing hot during Summer months girls would get heat stroke and puke in the passenger side coming up the GSP from the shore.
I miss it
31st March 2023
31st March 2023
