0 Passenger floorboards and backrest questions
Last Post: chris16371
0 Question about dynamic timing a 2000i
Last Post: jordan1200
0 How old are you?
Last Post: RandyMac
0 Galena IL
Last Post: Bad Dina
0 Issue that has me stumped
Last Post: night-train
Last Post: bplinson
Last Post: lugster
0 Who can make a spare key?
0 2 Up Seat Recommendations
Last Post: RKN
0 Carb, manifold issues
Last Post: davixlrtt
0 Fact or Fiction - HP Claims
6 1973 Sporty - Starts, Runs Good, Stops...
Last Post: 4th of July
Last Post: Beard111
0 Switch controls.
Last Post: shooterj2003
0 Does anybody know the difference between these two kits?
Last Post: Sadsack
0 Lake Erie Ride Alums?
Last Post: SteveK
0 1991 883 Hugger will not turn over
Last Post: Four Speed
Last Post: Diogenes415
0 S&S Super B float needle question.
Last Post: Captain Johnny
0 Analog Tach on 2004-2013 Sportster with OEM Digital Speedometer
Last Post: stray
9 MAP code problems
Old 3 Days Ago
Originally Posted by bigguyonline View Post
Best I can tell - Sw#1 - 5 is set to ON & Sw#6 is OFF...
Switch 1 is wrong - Needs to be OFF whether you're using the VOES or NOT...
Switch 2&3 are set for Curve#4
Switch 4&5 are set for 7000RPM Limit (back that down to 6500 - OFF/On)
Switch 6 is OFF - set for Dual-Fire
Is that picture showing your current switch settings?
Ultima Install / Timing Instructions:
http://www.ultimaproducts.com/53-644_Ignition.pdf
2 Relax
Old 3 Days Ago
bigguyonline bigguyonline is offline
Sportster/Buell Model: XLH883
bigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of lightbigguyonline is a glorious beacon of light
2 Relax
I believe I have switch 1-5 off and only switch 6 on
So I'm switch 1 = normal
Switch 2 & 3 = curve 1
Switch 4 & 5 = 5500
Switch 6 = single fire
I will double check however
Thanks
Sent from my Pixel 2 using Tapatalk
Old 2 Days Ago
Well - I hate to say it - But it seems the Ultima Ignition may be the culprit - Nothing else has affected the symptoms - And the symptoms are certainly like those when the nosecone ignition fails...
When the nosecone ignitions fail, they typically have trouble getting the timing right which causes the misfire & backfiring...
Before replacing the unit, which is spendy$$, we try to track down any other causes - but I don't see any other causes showing up here...
I would do the ground tests - See the Sportsterpedia page here:
http://sportsterpedia.com/doku.php/t...ng_is_critical
Be sure to check for a solid ground condition on the actual Ultima timing plate...
The battery ground & the harness ground should be mounted to the upper rear engine mount bolts (perhaps on different sides) - Be sure to remove those connections, clean them, then reinstall using a bit of copper-based anti-seize on the ring connectors (only use copper-based anti-seize on GROUND connectors - never on connectors for voltage)...
If the grounds look good everywhere, I think I'd be ready to replace the module...
2 Relax
Old 2 Days Ago
2 Relax
I'll do that this weekend and if all checks out and still persist after cleaning ground then I'll order. I'll come back and update.
Thanks
