0 Anyone around ENC, specifically wilmington - emerald isle
Last Post: RamblerAl
0 Tach/speedo
Last Post: Hornsmith
Last Post: ronccc
0 points/condenser
0 2004 ICM
Last Post: LLOYD883
0 A couple more noob questions
Last Post: Bikeaholic
0 Lifter / Tappet Please Gimme a Hand
0 Michigan Thumb Run:
0 Craigslist
0 How to long term storage?
0 Rear Crash Guard/Bag Guard Needed
Last Post: Turbo Sporty 48
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 Proper XLCH
0 Momentary starter switch installation question
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
Old 28th March 2020
GorilladaHun's Avatar
GorilladaHun GorilladaHun is offline
Sportster/Buell Model: 883 Superlow
Sportster/Buell Year: 2016
GorilladaHun is an unknown quantity at this point
I've got the Kuryakyn knurled flushmount on my Superlow and love it.
Old 29th March 2020
83ironman's Avatar
83ironman 83ironman is offline
Sportster/Buell Model: xlx1000
Sportster/Buell Year: 1983
Other Motorcycle Model: 2018 deluxe
83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future83ironman has a brilliant future
So they look cool. if you never get caught in the rain then great. I have found on my old chopper that with the flush mount cap. there is a lower than flush O-ring that seals and there is always a little bit of water that you can not see so that when you unscrew your cap the water drops in the fuel tank and allows the water to accumulate in the lower portion of your tank. So when popping up the cap blow the water out prior to unscrewing the cap. Owned it for 25 years so kinda tried a few different tricks.
83 XLX 18 FLDE
Old 29th March 2020
Consider where I live ...
2016 883 Superlow
Old 1st April 2020
vt883 vt883 is offline
vt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the roughvt883 is a jewel in the rough
Originally Posted by orvitarius View Post
Hello! I've been researching for quite a while, and though I found quite a bit of information, nothing was really specific.
I want to put one of those flush gas caps on a 2014 (ABS) Iron.
This one:
I've read people having leaking issues, other people not having any issues at all. I read the DK customs user talking about simply bending or pinching the venting/overflowing tube...
Any experience? Anyone who has pictures of having bent or trimmer the tube?
Thank you guys!
I've been running one of these since 2008.
https://www.dragspecialties.com/prod...oductId=576046
The only issue I had was the gasket that came with it didn't work well. I had to take a stock Harley gasket and cut it in half. No problems since.
Old 1st April 2020
Sportster/Buell Model: xl1250
I have the cheap one from Amazon. Needed to file the inside groove areas of the pop -up cap just a little bit. ( not the main housing that screws into fuel tank ) As it was a bit tight in function, works fine over the last 18months or so since being fitted.
Old 1st April 2020
Zero leaks, easy to use, great looking. That's enough reason for me. I love mine.
