0 Howdy From Texas
Last Post: XL1275
0 Can't find where oil leak is coming from. 1200C
Last Post: Mluke33
Last Post: Yakcm2
0 Replacement oil pump year 74
0 Down on oil
Last Post: Virto
0 Slip on muffler
Last Post: Joe_jeep
0 Starter wouldn't shut off
Last Post: XL Dane
Last Post: rocketnorton
0 1275 Kit and Krome Werks Headers?
Last Post: XL1275
0 Help Identifying Pistons
Last Post: Nitro57xl
Last Post: XL Dane
0 Riding pants repair?
11 How much did you spend on accessories in the first month?
Last Post: Virto
0 73 XLH For Sale, what's it worth
0 Nothing to See/Hear
0 Basket case
0 Oil leaking
Last Post: The Doctor71
0 Tach/speedo
Last Post: Mluke33
Last Post: bill smith
0 Stars and spanners?
Last Post: Meghanbrr
0 What Trips Do You have Planned for 2019
0 1968 xlch
duckster (70), 1ST_SPORTY (67), stein (58), tanksgt (51), tompie (47), eness76 (44), watsone020 (42), bohagon (32)
Old 19th June 2020
hondo hondo is offline
Other Motorcycle Model: 2000 ZX12R/1998 T595
hondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura about
Default Front Brake Master Cylinder Brake Light Switch
Is there any adjustment on the front brake light switch? The search function is down right now.
I have to ride with light pressure to the inside of the front brake lever to keep the brake lights off. In other words with normal vibration causing the front brake lever to jiggle turns the brake lights on and off.
Yellow Pearl 05 XL1200R:
Mikuni 42, .551, Doherty AC, Golan 5/16" FV, TC88a, Spark plugs indexed, Air caps on forks, Modified SE mufflers, Rear (red) turn signals are also running/brake lights, LED rear turn signal stalks, Front turn signals moved to lower tree, Laydown license plate, Fork brace, Sundowner seat, Whittlebeast hybrid rear shock mod, Arlen Ness Fairing.
Old 19th June 2020
No adjustment there.
Is your plunger spring weak? Sticky?
Have you changed the levers?
Parts breakdown here:
https://partsfinder.onlinemicrofiche...Y%20W/%20LEVER
Old 19th June 2020
rocketmangb's Avatar
You broke the plunger on the switch
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 20th June 2020
wedge's Avatar
wedge wedge is offline
It sounds like if you hold the lever forward the light goes out just fine right?
The lever should go all the way forward from the pressure of the spring behind the piston inside the MC. If it does not, you need to rebuild the MC. They get to where the lever doesn't return well from gum buildup inside the MC around the piston, (looks like green slime). Clean it out, replace the piston and the cups (you buy it as a packaged kit), it's cheap, flush out all the old fluid as you bleed, and when done the thing will act like new. The switch is a N-C switch (normally closed), so you know that the spring in the switch is good by the fact that it does push the switch out to make its normal contact. When you release the lever that pushes the switch in (when it is working right), plunger IN is the open position of the switch.
Note: examine that plunger, if you broke it off like Rocketman suspects you would have similar symptom, except I don't think pushing the lever forward would help unless there is a little piece of the plunger still there. They do break easy when you remove the lever unless you remember to put a small wedge in there to hold the lever back for removal.
Examine it closely and you will see what we are saying.
Old 20th June 2020
NLXL's Avatar
NLXL NLXL is online now
Yep! 'experience expert' here. Ruined one, same symptoms.
Next handlebar change I used a coin to get around 3 to 5 mm slack and a piece of tape to hold it in place.
(...I think it's even in the FSM......)
Sportsterpedia
"Logic will get you from A to B.
Imagination will take you everywhere."
Old 20th June 2020
rejeanprimeau's Avatar
Small screw can help, take the place of the broken button.
Old 20th June 2020
Never removed the front brake lever. Lever has 1/8" or so of slack. Removing the slack turns off the brake lights.
Thanks guys, I've got a rebuild kit sitting on the shelf. Perfect time to upgrade to dual S/S wrapped brake lines off the M/C.
Old 21st June 2020
wedge's Avatar
Yeah, you will be glad you did this, the MC is definitely gummed up.
