0 Generator conversion kit question
Last Post: 77IRHD
0 The Sport(ster)ing Life
Last Post: Sasnak75
0 S&S Super E Carb
0 Nup 1009 (Bearing)
Last Post: Racepres
0 Finnish custom rider
Last Post: FinnDRZ
0 so it's officially ended
Last Post: jzink0883
0 New to me 55kh
Last Post: 45Brit
0 AGM battery for 76' XLH
Last Post: JonesL
Last Post: BigMek
Last Post: 1200CustomHD
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
0 Cylinder head painting and battery and kick start advice
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
Last Post: retread08
0 front brake caliper interchange question
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Old 7th July 2020
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Damn Carburetors !
You need to work on your Carburetta Man, Super Hero Landing.
Old 18th July 2020
1stiski's Avatar
1stiski 1stiski is offline
Sportster/Buell Model: XL 883. CAFE conversion
Other Motorcycle Model: BMW R1200RT
1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light1stiski is a glorious beacon of light
I had a weird miss on my 2003 883 before, it ended up being worn out vacuum hoses, not broken , but cracked enough to seep air , and enough to create a miss on occasion .
No one said it would be easy.
Old 18th July 2020
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud ofkitabel has much to be proud of
IME problems that occur on high vacuum, and not WOT, are not electrical. More load makes the ignition quit, not improve.
No, it's not a sticking valve. Think about it...
I suspect a vacuum leak, manifold, intake guide. With engine idling, spray CO2, Argon, Freon, nitrogen all around the head - if the engine staggers it's an air leak.
Old 24th July 2020
Tustan's Avatar
Tustan Tustan is offline
Sportster/Buell Year: 1988
Tustan is an unknown quantity at this point
Starting fluid works too. Just put a rag between where you are spraying it and the intake cover.
