0 Howdy From Texas
Last Post: XL1275
0 Can't find where oil leak is coming from. 1200C
Last Post: Mluke33
Last Post: Yakcm2
0 Replacement oil pump year 74
0 Down on oil
Last Post: Virto
0 Slip on muffler
Last Post: Joe_jeep
0 Starter wouldn't shut off
Last Post: XL Dane
Last Post: rocketnorton
0 1275 Kit and Krome Werks Headers?
Last Post: XL1275
0 Help Identifying Pistons
Last Post: Nitro57xl
Last Post: XL Dane
0 Riding pants repair?
11 How much did you spend on accessories in the first month?
Last Post: Virto
0 73 XLH For Sale, what's it worth
0 Nothing to See/Hear
0 Basket case
0 Oil leaking
Last Post: The Doctor71
0 Tach/speedo
Last Post: Mluke33
Last Post: bill smith
0 Stars and spanners?
Last Post: Meghanbrr
0 What Trips Do You have Planned for 2019
0 1968 xlch
duckster (70), 1ST_SPORTY (67), stein (58), tanksgt (51), tompie (47), eness76 (44), watsone020 (42), bohagon (32)
Sc00'ter Sc00'ter is offline
Sportster/Buell Model: 1200 c
Sc00'ter is an unknown quantity at this point
Default rear rimfrom newer model
I have a 2000 xl1200c with solid wheel and a 130 tire, I am contemplating doing the 150 back there and I have seen most of the info for it to do it. I came across a rear laced wheel with the rotor and belt pulley off of a 2010 sportster with a michelin commander 150 on it. will this rim work for me, dont care bout the pulley so much because id like to do a chain conversion as well.
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
2010 has a larger axle 1 inch I believe. 2000 has a 3/4 inch axle. You will have to search for bearings with the correct i.d. and o.d. check in the wheels, tires section some may have done this. You may need to change your existing inner spacer as well. Check Sportsterpedia.com
There you will find all the specs for the wheel/ axle components ever used. There may even be sleeves that go between the 3/4 shaft and 1 inch inner race. Check out vulcan works/ engineering (something to that effect). They may have what your looking for.
I want backwards; 95 9 spoke mags with Vulcan's conversion parts. Worked like a charm. Good luck, I think you will be able to get it done. Also PBI has almost all the parts for a chain conversion.
Sent from my LM-X410(FG) using Tapatalk
