0 Top end rattle at 3000 rpm
Last Post: ReddTigger
0 Cam question
0 Loud pinging noise in top end (I think)
Last Post: andy2175m4
4 1995 S2 buell
0 Oil leak
Last Post: Roane
0 strange noise in top end
0 84 rear wheel spacer confusion
Last Post: supermotolew
0 Old new guy
Last Post: BruceClarke9
0 A Thanksgiving Gift Package For You!
0 Finnish custom rider
Last Post: fernf5
0 Loses Power
Last Post: straightshot
0 Look for a few odds & ends.
Last Post: dodgetrucken
0 BSA to be reborn...
0 H-D Quits Flat Track
Last Post: 45Brit
Last Post: XL1275
0 Roadster - No Key Start
0 Roadster Inverted Forks (again)
Last Post: Bone
0 Swingarm Bearing ID?
Last Post: Andy56
Last Post: iBloke
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
The carb body has one screw, the Idle Mixture Screw, located top rear center by the manifold flange. Looking down the throat, off to the left is the idle speed/throttle stop screw, and on the right in with the choke assembly is the fast idle adjust screw.
I think I figured out the mystery vacuum port too. The one that's capped was added for VOES in '83, then the one in the back on the manifold flange (the one that's in use now) was added for the same purpose in '84 but they didn't bother to remove the earlier one. So make extra sure that port is actually capped and isn't leaking!
The second port is for purging a charcoal canister.
Most have been removed (if it had one).
npaisnel npaisnel is offline
Sportster/Buell Year #2: 1993
npaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond repute
OK, thanks guys...if the owner of the bike has not signed up here and come to this thread..then we can close it here...can only try and help so much...
Have sent him the link not here a couple of times and said to sign up...if he has not ..his loss
The port behind the throttle plate is for the VOES, the port closer to the air filter is for the canister purge.
