0 Top end rattle at 3000 rpm
Last Post: ReddTigger
0 Cam question
0 Loud pinging noise in top end (I think)
Last Post: andy2175m4
4 1995 S2 buell
0 Oil leak
Last Post: Roane
0 strange noise in top end
0 84 rear wheel spacer confusion
Last Post: supermotolew
0 Old new guy
Last Post: BruceClarke9
0 A Thanksgiving Gift Package For You!
0 Finnish custom rider
Last Post: fernf5
0 Loses Power
Last Post: straightshot
0 Look for a few odds & ends.
Last Post: dodgetrucken
0 BSA to be reborn...
0 H-D Quits Flat Track
Last Post: 45Brit
Last Post: XL1275
0 Roadster - No Key Start
0 Roadster Inverted Forks (again)
Last Post: Bone
0 Swingarm Bearing ID?
Last Post: Andy56
Last Post: iBloke
after giving this some more thought this morning i remembered i did this about 8 or 9 yrs. ago during my Andrews gears and shafts upgrade.the trans. and shifter shaft were not in the cases at the time.your shifter shaft is still installed so it's an obstacle for that procedure. it could still be done but you would have to put a slot in the pipe spacer to pass over the shaft.after the bushing would be driven out you would have to cut a slot in it tor removing that.not as trouble free with the shaft still in the trans.
Doc308 Doc308 is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Panhead EL
Other Motorcycle Year: 1948
Doc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to all
Yeah-- my transmission seems fine and won't be coming out. I'll just proceed with removing the cam cover. Thank you for the info, friends!
sleighcrane's Avatar
sleighcrane sleighcrane is offline
Sportster/Buell Year: 1967
Other Motorcycle Model: FLHR
sleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to all
Because nobody has mentioned this but I seem to recall many years ago we would pull the sprocket cover for observation purposes and tap a new bushing in from the outside and then cut off the old one from the inside or maybe even leave the old one on the shaft. Like I said many years. Good luck with the repair
