0 883 rev range
0 passenger with driver's backrest
Last Post: Veeflys
0 Chain drive vss
0 yost power tube guy
0 oil filter stuck
Last Post: Bikeaholic
0 New Lifters with new cams with your conversion?
Last Post: yelladox
0 S&S Super E
Last Post: RussW
Last Post: TPEHAK
0 Ia 83 xlx
0 is a buell a harley
0 Hawkeye's 1275 Hammer Performance Conversion
Last Post: hexnut
0 how to reduce buffering
Last Post: Stude
0 Sidehack for XLS
0 Proper XLCH
Last Post: revjen45
0 73 xlch gas flowing from carb
0 Iron 1966 XLRTT
Last Post: xlerate
0 Your Favorite Style
Last Post: AZbiker
Last Post: Marsikus
0 1983 Ironhead - Oil not Returning
  #71
Old 3 Days Ago
CCC CCC is offline
Sportster/Buell Model: 1200S Sport
CCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to allCCC is a name known to all
I bought a pair of progressive 412 HD I think they were 13" that was one of the best things I did as far as helping the handling. Right back and then increased the fork springs rate with a progressive HD set of springs if you haven't done that already you should because they handle night and day in difference.
Old 14 Hours Ago
revjen45 revjen45 is offline
Sportster/Buell Model: XLS1000
Sportster/Buell Year: 1979
Other Motorcycle Model: Norton Ranger
Other Motorcycle Year: 1968
revjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant futurerevjen45 has a brilliant future
Stopped in at the shop today. After pulling the heads to replace the rocker cover gaskets the owner said the motor looked gently used and ready to go. Sheet metal is in the paint shop. It will replicate the original color scheme with the 3.2 gal. Sportster tank and a matching gray panel with gold pin stripes on the hack. Now I need to decide on the tank emblem - liking the traditional bar and shield in dark gray & black to match the XLS color scheme. Onward and upward!
Better to perish in the struggle for freedom than survive to see defeat.
Old 13 Hours Ago
mikethebike61's Avatar
Originally Posted by CCC View Post
Hey get ready for one helluva an experience. I'm gonna go ahead and tell you know it's nothing like it looks on TV and you need to drop a tooth or 2 on the transmission drive sprocket..at least one anyway and definitely run straight 50w or 60w motor oil. A sportster isn't a choice motorcycle to tug with..no way but they have strong frames and that's good and safe.
If I can help you with your subframe let me know I built mine because they were 1k everywhere else.
Please support your advice to run straight weight oil
Seeing as 25/60 XTC is the same viscocity at temp as straight 60
Same with any multi viscocity oil
20/50
15/50
15/60
at temp it is all the same.....ther is zero advantage to running straight weight engine oil
ZERO
