Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 > XR-1200
XR-1200 This area is strictly for XR-1200 discussion only
0 Replace lifter(s) w/out teardown?
Last Post: canoli
0 S&S Super E Carb
0 Oil not returning to tank
0 Sportsters in movies and TV
Last Post: dodgetrucken
0 100 vs 110 front tire
0 Fair price for used parts
Last Post: rivethog
0 Mikuni - hangin revs
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
0 Riding music
0 Xr750
Last Post: Armand
Last Post: CCC
Last Post: slojoe631
0 Xl???
0 Help me identify this washer
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
  #451
wedge's Avatar
wedge wedge is offline
Yep. A thrust bearing makes no sense to me either. I would throw a regular bearing in there and call it a done job. It looks like a bearing will still press into place so why not try to salvage it first? All that will cost is the price of the bearing.
wedge's Avatar
I see why they did it now. It's still a poor design, but maybe you can use a 7200B throwout bearing in place of it (or similar design)?
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
It lasted 8 years. I may be mistaken, but isn’t this bike used on gravel/dirt roads often? It appears that it has never been serviced judging from the condition of the hardware. I would say that if I am correct on those statements, it served a very usable life. I wouldn’t hesitate to purchase the same item, but perhaps this time find a way to service the bearing a bit more frequently. Or replace the bearing itself at the 7 year mark.
If I’m thinking of a different bike... carry on.
Davo_137's Avatar
Davo_137 Davo_137 is offline
Yes I’m partly responsible for the failure. I should of serviced it more often for sure. Unfortunately i didn’t know or forgot it was just a thrust bearing in there. Live and learn.
I still have the oem bracket for the idler pulley at home, I’ll use that for now and maybe down the track take a look at fitting some different type of bearings in the freespirits bracket. I’m not sure there’s enough meat left on the outer edge to do this though. I have a friend who is a machinist, he will point me in the right direction.
wedge's Avatar
Well, your machinist should be able to make something way better. The reason for the thrust bearing is because in this design the two races each mount in one half of the pivot and I assume the bolt sets the load on the balls? If you use a regular bearing you will need to mount it to one of the plates, and the bolt will just go through the second plate and solidly tighten to the inner race.
Now that I am thinking this through I am thinking that they used the bearing that they used because a standard bearing would have eventually fallen out of the plate it is pressed into due to movement over time.
So, bottom line is that your plan to buy another one sounds like the most logical course of action.
Davo_137's Avatar
Yes that’s right, the thrust bearings allow it to pivot. But there is no sideways load or very little. The load comes from the belt pushing down on the idler pulley. I don’t think thrust bearings are designed to take that sort of load. So a poor design imo.
I’ll see what my friend has to say about retaining and making standard ball bearings work in there.
Davo_137's Avatar
I found the original idler bracket. Bonus is I stored it with the original pulley bolt screwed into it.
I’ll put it on the bike later, I still have night shift lag at the moment.
Old 1 Day Ago
Davo_137's Avatar
The kangaroos around the site are used to people and noisey machines. Momma roo with her baby.
They cut down this big old tree and turned it into table at Bedford weir.
