0 15 min rides
Last Post: 201648Rider
Last Post: kkbii
0 68 XLCH - Insight Plz
Last Post: sleighcrane
0 anyone recognize these pistons?
0 What if? race ITT 1250
0 Help me identify this bike
0 A Truck and Two Saddle Sores on Two Bikes to Jacksonville
0 Shaking front end
0 harbor freight lift
Last Post: stick shift
0 HF bike lift
Last Post: Tonyb65
0 Who runs 70wt. oil
0 2003 1275 BFH 120hp still pings when going full throttle
Last Post: stikflote
0 XL Forum will now be the Suzuki Intruder Forum
Last Post: xraytoken
0 Who Runs Turn Signals?
0 Greetings from Denmark
Last Post: AKL1
3 How To Post Photos
Last Post: AKL1
0 Just saying G'day
Last Post: Coz
0 Xl1200c
Last Post: Joe_jeep
Last Post: Doc308
0 Need help picking new mufflers
kanger, Leef (75), pwilson1204 (72), TomW (61), micke (55), rat481 (51), Jason2009 (49), runsummore84 (36), wishbone550 (33)
Old 7th June 2014
sportsterdoc's Avatar
Default Voltage readings - why we need them
Why every M/C rider should have a voltmeter/ohmmeter (multimeter) and post voltage values when asking about a problem:
A. Many suspected fuel issues turn out to be electrical.
Some suspected ignition module issues (rigid mount) turn out to be voltage related.
B. A huge amount of issues are caused by battery cable deterioration and/or loose connections, especially on the negative cable to the frame. This is true on all Sportsters but seems to be even more so on the rubsters (04 up), as the motor moves more, in relation to the frame.
It is a handicap when Forum members do not include their geographic location in the “About Me” section. This is germane to corrosion. (It also has a bearing on carb tuning, in regards to elevation, etc.)
Whenever there is a problem that may even remotely be electrical, it would be helpful to post the following voltage readings:
1. KEY OFF battery voltage, at the battery: Normal is 12.8, acceptable is 12.6 (standard lead acid battery, not AGM) to 12.8 for no load. If just taken off a charger, voltage may be 13 point something. The battery needs to sit for a while before a reading is useful. In the case of a bad cell, the other cells overcharge and give an almost normal reading, until load is applied.
• If lower, then battery is discharged and needs charging or
• Battery has a bad cell
2. KEY ON battery voltage (headlight on): Normal is not under about 12.5 initially, but will decline the longer that the headlight is on, without the motor running. Under no load, 12.5 volts indicates 50% discharge, but under load, it is just voltage drop.
• Battery has a bad cell or
• Battery cable(s) have high resistance
3. KEY ON battery voltage while cranking: Normal is not under 10.5 volts
• Battery cable(s) have high resistance or
• Starter is drawing too much current
4. If the bike is running, battery voltage at about 2,500 RPMs should be 13.8 to 14.8
• If not, then check stator resistance and regulator ground
• If the stator is not shorted to ground and resistance is within spec, the regulator or regulator ground is suspect
5. When there is a problem with “no power” check the 30 amp circuit breaker or maxi fuse between the battery and the key switch and all the 15 amp fuses after the key switch (or circuit breakers on many Ironheads). If circuit breakers / fuses are OK, then measure voltage coming into the key switch and continue downstream until the voltage stops.
Hope that this helps you and us find your problem quickly.
Old 24th June 2014
the48'ster's Avatar
the48'ster the48'ster is offline
Sportster/Buell Model: Forty-Height
the48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of lightthe48'ster is a glorious beacon of light
good info. Very informative and kind of a icebreaker for people like me who are just learning this stuff. (electrical diagnostics)
The greatest trick the devil ever played was convincing the world that he did not exist.
Old 24th June 2014
cHarley04's Avatar
cHarley04 cHarley04 is offline
Sportster/Buell Model: XL1200C/1250
Sportster/Buell Year: 04
cHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant future
Very good writeup, too bad there's not a way to make it a Must Read Before You Can Post item.
Two items that might be added to or clarified are:
B. on the rubbermounts, I think it's as much about the the motor being isolated from the frame which dictates the need for good, clean & tight ground straps, as it is movement.
1. Turning the ignition On for 3 seconds, then back Off (headlight on then off) will bleed the excess residual voltage left on the battery after removing a charger. No need to wait awhile to get a true reading.
Again, nicely done.
Hammer 1250-Smash Heads-560 Cams -Hurricane Flow AC -Supertrapp Supermeg -TC88A
Old 24th June 2014
darth's Avatar
darth darth is offline
Sportster/Buell Year: 2014
Sportster/Buell Model #2: 1200C/Champion Trike
Other Motorcycle Model: 1200C/Champion Trike
Other Motorcycle Year: 2010
darth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant future
Good point!
Darth
2010 XL1200C (Mine)
2009 XL1200C / Champion Trike Kit (Hers)
My Gallery
Ol' Wrench Head of the White Werewolfes MC
Old 21st October 2014
nleco's Avatar
nleco nleco is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1984
nleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to behold
Thank you so much for this.
2009 Iron
  • 1250 Hammer Kit
  • 30 degree reverse dome pistons
  • 1.770 7MM Intake 4.520 TG Conversion
  • 1.530 7MM Exhaust 4.610 TG Conversion
  • Striker Performance 7MM Valve Spring 550 Lift Triple Grove Locks/Beehive Springs
  • Competition Valve Job
  • 560 Impact Cam Set
  • Bronze Oil Pump Gear
  • Dragtron II AC
  • V&H Shortshots
1984 Ironhead
Glad to be of some help
Old 24th March 2016
Doc - I put this up on the Sportsterpedia (with minor editing)...
http://sportsterpedia.com/doku.php/h...trictech:start
Thanks
__o~~o__
IXL2Relax
Old 24th March 2016
Good, thank you for making it more accessible
Old 24th March 2016
Make it a sticky here too please!
Basic primary diagnosis checks for any IC vehicle. They all need juice.
Plus any electrical diagnosis is invalid without a properly charged and adequate battery to power the components
Good work Sportsterdoc.
Joe
Old 24th March 2016
Joe
Thanks, Joe
Chuck (cantolina) made one of my threads a stickie (Bank Angle Sensor Bypass) and I think he is the electrical section moderator...but I have not seen him post much lately.
Answering these few questions (and understanding why they are asked) may help us help with some problems sooner.
