4 greetings from quarantine!
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: vagrant318
0 2019 xl1200 suspension upgrade
Last Post: Bikeaholic
0 Oil Leak ??????
0 XR1200 for trail riding
0 Low Profile Scissors Lift
0 Intake seals, glad I checked them
0 Sportster Tank Art
Last Post: Bryan83taco
0 Why cafe a sportster?
Last Post: Merch131ho
0 Spark Plugs
Last Post: Joe_jeep
0 74' XLCH wiring question
0 Resto-Repair 84 ironhead
0 Diagnostic code ?
0 No spark
0 FNG from Oregon
0 How packed is your garage?
0 Started my chop today!
Last Post: skid_ro
0 Ceramic Wax
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
ironhead, noise, transmission
Old 1st October 2014
Matt397's Avatar
Matt397 Matt397 is offline
Sportster/Buell Model: XL1000 stock/near stock
Matt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to beholdMatt397 is a splendid one to behold
Pulling the primary cover was definetly the right thing to do. Look closely with plenty of good light after swabbing things down with solvent and inspect for witness marks, chips or scratches.
Was there any debris in the oil?
How does the starter drive look?
Is the crank sprocket tight?
Before you pull the trans out spin it through all the gears with both the primary and drive chain removed. Feel for any binding....anything that would cause the "klunk" should be noticeable.
Matt
rejeanprimeau's Avatar
They clunk when you change gear, and when you start it, the selenoid clunk.
geo.ulrich's Avatar
geo.ulrich geo.ulrich is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: #2 xlch hardtail
Sportster/Buell Year #2: 76
geo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the roughgeo.ulrich is a jewel in the rough
changes with rpm and all gears, does this include neutral? not the solenoid bike is already running..
charliej charliej is offline
Sportster/Buell Year: 79
charliej is an unknown quantity at this point
Matt
Thanks Matt I will be doing this tonight everything looks good in the primary case. And yes at idle in neutral it clunks slightly less but with the same frequency just not as loud as in gear
geo.ulrich's Avatar
2 things I would look at grab clutch hub and try to see if it moves in and out or side to side, motor sprocket same thing see if it moves in and out. lets hope not...
Old 4th October 2014
Transmission was missing 2 teeth on 2 separate gears of the countershaft does anyone know what gears will fit 1979 1000cc electric start ironhead
doodah man's Avatar
'54-e'84 with the exception of the early 1st gear w/speedo drive ('72 and earlier) on the counter shaft will work. main shaft, all gears except clutch gear ('71-e'79 and 'L79-e'84; small differences) will work. how do the adjacent gears on the main shaft look?
They look fine so what can I just buy the counter shaft from any ironhead after 72 and be done with it?
doodah man's Avatar
i'd say '73 and later, but you will still have to go through the process of setting gear clearances; with new gears the spacing will probably/likely change.
