Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Organize a Group Buy
Organize a Group Buy Here is where you can organize a group buy. Anyone can organize a group buy to include commerical vendors. This is only section that non-supporting vendors may mention their products but only in conjunctions with a group buy.
0 su carb question
Last Post: Lolzcat
Last Post: PetesPonies
0 Rear Master Cylinder Rebuild or New?
0 Frame bracket
Last Post: Bwf347
0 Happy Birthday Mrs. Folkie.
Last Post: TUCCI
1 Three Harley-Davidson Sportsters That Don’t Care What You Think
0 Spoke hub bearing assembly
Last Post: Jonv
0 my recent ebay purchase
Last Post: Moon Wolf
Last Post: Bikeaholic
0 Best Tuner options?
0 top end noise
0 In tank fuel filter on 2004 xlc
0 LED headlight caused problems
0 Barnet clutch spring plate
Last Post: dayypete
0 Hi from Barcelona!
2 My 1275 Hammer Conversion..
Last Post: wrkdWS6
0 '86 1100 basket build
Last Post: Onlybckroads
Last Post: fafcpa
Last Post: wrkdWS6
0 Front brake calliper strange noise...
0 How tricky is it to replace dipstick trim from oil tank?
Old 5th November 2014
randytelecaster randytelecaster is offline
randytelecaster is an unknown quantity at this point
Default New Evo Front cylinder head
If we could get a foundry to do a production run of about 200 who would want to purchase a front cylinder head with the intake port on the other side to EFFECTIVELY have dual carbs or dual throttle bodies for electronic fuel injection ?
Old 26th November 2014
mach1charlie's Avatar
mach1charlie mach1charlie is offline
Sportster/Buell Model: XL 883/1200
Sportster/Buell Year: 92
Other Motorcycle Model: RZ350KLR650GT750KZ1000C10
mach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the rough
I really like that idea. Thought about cutting and welding a stock head. 1 casting could do sportster and big twin evo, with different finish machine work
Charlie
Charlie I have a couple of front iron cylinder heads and have studied doing that but there just isn't an easy way. I want to run two front heads and maybe raise the intake port on the front cylinder since it is too big to have good flow velocity anyway. I'm sure doing that on an aluminum head would be easier. It would give more room for the exhaust on the other front head that would be used on the back and should provide better flow characteristics.
Old 26th November 2015
aa799122 aa799122 is offline
Sportster/Buell Model #2: buell
Sportster/Buell Year #2: xb
Other Motorcycle Model: flhxs
Other Motorcycle Year: flxs
aa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to allaa799122 is a name known to all
I am in!!count me for 2
